Is Mr Dejong taking on VCDS Coding Challenges!!
TurboTrev
If Mr Dejong is considering taking on VCDS coding challenges :grin: , it would be great if coding instructions could be worked out for:
Rear lights to come on with the light switch in the off position so they are on with the full power front drls (front drls dim when switched to the sidelight position). I believe it's some sort of Scandanavian setting?
Brake light extended across the inner light cluster (know as the full width brake light mod on the GTI forum thread below).
Inner drl to be set at 100% to match the outer (at the moment it's slightly dimmer, probably around 80%?).
There a number of mods on this 7GTI thread that may work/could be adapted for the 7R? http://www.golfgtiforum.co.uk/index.php ... 260248.610
Many thanks. :afro:
  • Replies 1
