marcton Posted December 1, 2014 Report Share Posted December 1, 2014 I am wanting to buy a tuning box and keep my warranty intact (hopefully) but the lack of definite info is putting me off. Am i right in thinking that tuning boxes alter info from the boost sensors to effectively raise boost? If so....does the ecu automatically compensate for this regarding fuelling or does the car run leaner? Also whats with the massive selection of settings? The 1-3,2-2,3-3 business could be made easier.....surely you just need off and on. I've phoned a company selling the tuning boxes but the chap was just quoting the sales ad about increased throttle response, drivability and multiple settings to suit my driving style....this should have put me off but i want extra power and a warranty. Thanks in advance for any info Quote Link to comment Share on other sites More sharing options...
Deako Posted December 1, 2014 Report Share Posted December 1, 2014 It will void your warranty if detected parameters are outside of standard. Risk you take. Kev.k 1 Quote Link to comment Share on other sites More sharing options...
marcton Posted December 1, 2014 Author Report Share Posted December 1, 2014 It will void your warranty if detected parameters are outside of standard. Risk you take. Why not contact our forum sponsors for more detailed information. I don't understand why you are bothered about the settings. You don't have to change them, just leave it at default. However you can if you so like. Simples. Regarding warranty, ANY non manufacturer modification may have an impact on warranty. If you aren't comfortable with that then you shouldn't do any modification and just leave the car as it comes. Again a very straightforward concept I would have thought. thanks for the info Quote Link to comment Share on other sites More sharing options...
B13NGL Posted December 17, 2014 Report Share Posted December 17, 2014 After reading multiple treads regarding tuning box's, remaps and such like along with a close friend being the director of PERON Automotive (specialises in ford tuning), this is my opinion. I would say a re-map would be safer for your car. a remap's designed to work correctly with your engine, your ECU's still in full control. A tuning box works basically by tricking your ECU to think different parameters are being passed, this does actually cause fault codes if read with a VCDS. if a tuning box F'd your car I would guess VW would be able to figure it out based on boost values recorded previously anyway. So i would assume that a revo stage 1 will be less likely for you too need warranty work (due to the map) vs tuning box, you could take it off but if they dug deep into the diagnostics they could find out. Also a stage 1 will yield the best performance results. Quote Link to comment Share on other sites More sharing options...
nuvolablue Posted December 17, 2014 Report Share Posted December 17, 2014 You also need to consider the TD1 flag question. Quote Link to comment Share on other sites More sharing options...
Scott7R Posted December 17, 2014 Report Share Posted December 17, 2014 . Quote Link to comment Share on other sites More sharing options...
MIGLIOR Posted December 17, 2014 Report Share Posted December 17, 2014 I've had a tuning box on and there was no fault codes on VCDS No but if something in the engine failed, a snapshot of all the values of the engine will be saved. It might even be possible to clear these but sometimes with catastrophic failure, access to the right modules with diagnostics is easier said than done to clear them Quote Link to comment Share on other sites More sharing options...
nuvolablue Posted December 17, 2014 Report Share Posted December 17, 2014 I don't dispute that. In fact it's one of the reasons I binned the tuning box. Also If you end up in a field on your roof you are hardly going to get out and remove the box.You might. Plus you would have more chance of doing that than removing the map. Quote Link to comment Share on other sites More sharing options...
Scott7R Posted December 17, 2014 Report Share Posted December 17, 2014 You might... But chances are it won't be accessible. Quote Link to comment Share on other sites More sharing options...
southall87 Posted December 17, 2014 Report Share Posted December 17, 2014 Also If you end up in a field on your roof you are hardly going to get out and remove the box. Would make it easier to get to that bottom sensor andyshez and Mickylad 2 Quote Link to comment Share on other sites More sharing options...
Scott7R Posted December 17, 2014 Report Share Posted December 17, 2014 Haha it would that! But then the bonnet would be wedged shut Quote Link to comment Share on other sites More sharing options...
B13NGL Posted December 17, 2014 Report Share Posted December 17, 2014 If you remove a map the TD1 flag is still shown so removing Its pointless Quote Link to comment Share on other sites More sharing options...
