bah434x Posted March 7, 2015 Report Share Posted March 7, 2015 Making some changes tmrw on the MK7R Anything else worth while doing? My list so far.... Alarm chirp Sound actuator volume Rear brake lights DRL Brightness Puddle lights on while folding Automatic rain closing Cheers Quote Link to comment Share on other sites More sharing options...
andy3141 Posted March 7, 2015 Report Share Posted March 7, 2015 I did a few other small mods such as: Delay headlight washers. Show fan speed whilst in auto AC mode. Add on/off option for drls in the main car menu. Quote Link to comment Share on other sites More sharing options...
bah434x Posted March 7, 2015 Author Report Share Posted March 7, 2015 I did a few other small mods such as: Delay headlight washers. Show fan speed whilst in auto AC mode. Add on/off option for drls in the main car menu. I'd be interested in headlight washer option coding.. Quote Link to comment Share on other sites More sharing options...
andy3141 Posted March 8, 2015 Report Share Posted March 8, 2015 I'd be interested in headlight washer option coding.. Select STG 09 (vehicle power) STG access permissions -> Function 16 Enter access code 31347 STG adjustment -> Function 10 Channel (3) - select windshield wipers SRA washing time Adjust value (from memory the max value you can set is 2500ms) MoMez 1 Quote Link to comment Share on other sites More sharing options...
Big al Posted March 8, 2015 Report Share Posted March 8, 2015 Making some changes tmrw on the MK7R Anything else worth while doing? My list so far.... Alarm chirp Sound actuator volume Rear brake lights DRL Brightness Puddle lights on while folding Automatic rain closing Cheers How do you alter things like this ? Quote Link to comment Share on other sites More sharing options...
bah434x Posted March 8, 2015 Author Report Share Posted March 8, 2015 How do you alter things like this ? You need a cable that connects the the OBD2 port and the software, around £250 for the package, or find someone who has one local and buy them a beer... Big al 1 Quote Link to comment Share on other sites More sharing options...
bah434x Posted March 8, 2015 Author Report Share Posted March 8, 2015 Select STG 09 (vehicle power) STG access permissions -> Function 16 Enter access code 31347 STG adjustment -> Function 10 Channel (3) - select windshield wipers SRA washing time Adjust value (from memory the max value you can set is 2500ms) Cheers Is there a way to enable the passenger side rear fog? Looks like the LED's are there Quote Link to comment Share on other sites More sharing options...
andy3141 Posted March 8, 2015 Report Share Posted March 8, 2015 Cheers Is there a way to enable the passenger side rear fog? Looks like the LED's are there Not that i know off. I believe that it requires a hardware change. Quote Link to comment Share on other sites More sharing options...
neg Posted March 8, 2015 Report Share Posted March 8, 2015 Can you explain the headlight washer option ? bah434x - what do you mean by DRL brightness? Items I have changed... DRL brightness when headlights on -also works for Coming Home DRL dimming when indicators on, fade in/out Fan speed shown when A/C on Auto Alarm Beep + enable on Navigation display Extended Brake Lights - using boot lid LEDs Traffic Sign recognition Seatbelt warning Quote Link to comment Share on other sites More sharing options...
andy3141 Posted March 9, 2015 Report Share Posted March 9, 2015 Can you explain the headlight washer option ? bah434x - what do you mean by DRL brightness? Items I have changed... DRL brightness when headlights on -also works for Coming Home DRL dimming when indicators on, fade in/out Fan speed shown when A/C on Auto Alarm Beep + enable on Navigation display Extended Brake Lights - using boot lid LEDs Traffic Sign recognition Seatbelt warning Headlight washer delay basically means that if you pull the stalk to activate the windscreen washers (whilst your lights are on) it will delay the headlight washets from activating for X amount of time. In my case I have set the delay to 2.5 seconds, this means as long as i dont pull the stalk back for more than 2.5 seconds then the headlight washers never activate! Which for me is much better as i find the washer fluid lasts a lot longer before needing refilling. Quote Link to comment Share on other sites More sharing options...
AdDaMan Posted March 9, 2015 Report Share Posted March 9, 2015 Yeah that's a great feature. Anyone in SE have VCDS? Quote Link to comment Share on other sites More sharing options...
neg Posted March 9, 2015 Report Share Posted March 9, 2015 That sounds good, more control. I'll add that to my list. Is that the current version? I tried finding that entry but didn't see one matching. Quote Link to comment Share on other sites More sharing options...
bah434x Posted March 18, 2015 Author Report Share Posted March 18, 2015 Anyone no the details for this one? https://www.facebook.com/video.php?v=727942357320784 Oh someone posted it Quote Link to comment Share on other sites More sharing options...
neg Posted March 18, 2015 Report Share Posted March 18, 2015 Not sure on that one myself. Quote Link to comment Share on other sites More sharing options...
Stobsie Posted March 18, 2015 Report Share Posted March 18, 2015 I do like to tinker with VCDS but think i will give this one a miss, the Disco look is not for me. Quote Link to comment Share on other sites More sharing options...
