Lowflying Posted January 5, 2017 Report Share Posted January 5, 2017 Try link below http://www.vwwatercooled.com.au/forums/f197/vcds-vag-com-codes-programmable-options-golf-mk7-84619-post1154325.html#post1154325 Hi Don, or anyone else with great vcds knowledge, please help me with the following anomaly. I have used the guide below to have pace car hazards (as video above), but keeping the normal indicators . All works fine except when I turn the ignition off, but leaving the hazards lights on. For some reason the inner tail lights stop flashing, leaving only the outer lights flashing. I used the following guide, (see link) http://www.vwwatercooled.com.au/forums/f197/vcds-vag-com-codes-programmable-options-golf-mk7-84619-96.html#post1203303 Wondered if both lines are supposed to say exactly the same in "Active with Hazard warning lights" or is there an error in these instructions? cheers Jon Quote Link to comment Share on other sites More sharing options...
dv52 Posted January 5, 2017 Report Share Posted January 5, 2017 Hi Don, or anyone else with great vcds knowledge, please help me with the following anomaly. I have used the guide below to have pace car hazards (as video above), but keeping the normal indicators . All works fine except when I turn the ignition off, but leaving the hazards lights on. For some reason the inner tail lights stop flashing, leaving only the outer lights flashing. I used the following guide, (see link) http://www.vwwatercooled.com.au/forums/f197/vcds-vag-com-codes-programmable-options-golf-mk7-84619-96.html#post1203303 Wondered if both lines are supposed to say exactly the same in "Active with Hazard warning lights" or is there an error in these instructions? cheers Jon Jon: Well done for finding the deliberate error! Seriously, my apology - I did make a boo-boo. Yes, you are correct - the second (16)-Dyn. turn signal modes-Warnblinken_Zuendung_EIN in my instructions should have been (17)-Dyn. turn signal modes-Warnblinken_Zuendung_AUS, which activates the facility when the ignition is switched-off. I've changed my original instructions so that I won't confuse others Thanks again Don Quote Link to comment Share on other sites More sharing options...
Lowflying Posted January 6, 2017 Report Share Posted January 6, 2017 Jon: Well done for finding the deliberate error! Seriously, my apology - I did make a boo-boo. Yes, you are correct - the second (16)-Dyn. turn signal modes-Warnblinken_Zuendung_EIN in my instructions should have been (17)-Dyn. turn signal modes-Warnblinken_Zuendung_AUS, which activates the facility when the ignition is switched-off. I've changed my original instructions so that I won't confuse others Thanks again Don Don: thanks for getting back to me, you are the oracle! I will try this later cheers Jon Quote Link to comment Share on other sites More sharing options...
