mot44 Posted June 4, 2015 Report Share Posted June 4, 2015 Hi, I've posted about this before but just wondered if this is the proper way to code the Golf R indicators in so the flash like on a pace/safety car because i have tried and its not worked for some reason. Am i missing something out? Its a December 64 plate 09 Cent Electricssecurity access 3134710 Adaption(4) -Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A16When I've clicked on channel it says ERROR: Channel Not AvailableHas anybody else had this? Many Thanks Quote Link to comment Share on other sites More sharing options...
neg Posted June 4, 2015 Report Share Posted June 4, 2015 Doesnt look right as you need to code both side, I did one wrong when I first did it so I had the left inside flashing with the right side lol Think this is what you need ... Select -> 9 Central Electronik -> Security Access -> 31347Adaptation -> Channel: (4) Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A16: Set = Blinken lins Dunkelphase. (Default:Blinken Links Hellphase)Adaptation -> Channel: (4) Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A17: Set = Blinken rechts Dunkelphase. (Default: Blinken rechts Hellphase) Always take note of what your settings are before you change them so you can revert back Quote Link to comment Share on other sites More sharing options...
182_blue Posted June 4, 2015 Report Share Posted June 4, 2015 On top of what Neg says Sometimes it can play up, you need to go out and back in again sometimes (maybe numerous times) and it should let you in. Quote Link to comment Share on other sites More sharing options...
adam. Posted June 4, 2015 Report Share Posted June 4, 2015 Sometimes you gotta go to the menu on the media screen and reset the light section to default after you change anything to do with indicators/lights. Quote Link to comment Share on other sites More sharing options...
AdDaMan Posted June 4, 2015 Report Share Posted June 4, 2015 What does this do?! Quote Link to comment Share on other sites More sharing options...
neg Posted June 4, 2015 Report Share Posted June 4, 2015 this ... AdDaMan 1 Quote Link to comment Share on other sites More sharing options...
AdDaMan Posted June 4, 2015 Report Share Posted June 4, 2015 Love that. I'm doing it.. Quote Link to comment Share on other sites More sharing options...
AdDaMan Posted June 4, 2015 Report Share Posted June 4, 2015 It does it on indicators aswell right, not just hazards? Quote Link to comment Share on other sites More sharing options...
AdDaMan Posted June 4, 2015 Report Share Posted June 4, 2015 Just been out and done mine. works on indicators too. Quote Link to comment Share on other sites More sharing options...
AdDaMan Posted June 4, 2015 Report Share Posted June 4, 2015 https://vimeo.com/129834476 Quote Link to comment Share on other sites More sharing options...
Stobsie Posted June 4, 2015 Report Share Posted June 4, 2015 https://vimeo.com/129834476 You will more than likely give the person driving behind you a Epileptic fit with that mod. AdDaMan 1 Quote Link to comment Share on other sites More sharing options...
AdDaMan Posted June 4, 2015 Report Share Posted June 4, 2015 Lol! I am wondering if it will be severely annoying or not... Quote Link to comment Share on other sites More sharing options...
TechieAli Posted June 5, 2015 Report Share Posted June 5, 2015 Not sure I like the look of it. Is it legal here as well? Quote Link to comment Share on other sites More sharing options...
tamiyoman Posted June 5, 2015 Report Share Posted June 5, 2015 Nope, don't like that! dv52 1 Quote Link to comment Share on other sites More sharing options...
sbp Posted June 5, 2015 Report Share Posted June 5, 2015 Looks better when the lights are on with it but not overly keen if I'm honest. Quote Link to comment Share on other sites More sharing options...
