Dr'R'
Everything posted by Dr'R'
  1. Rear pads replaced today, all went well. Thanks again for all the assistance๐Ÿ‘
  2. Rear pads replaced. Nice easy and straight forward job. Then gave it a well over due bath.๐Ÿ˜Š
  3. I'll avoid using the app, and just find the coding sequence req to replace the rear pads. Thanks again๐Ÿ‘
  4. I'm running on some Goodyear Eagle F1's. Can't fault them๐Ÿ‘
  5. I do have the Pro version of OBDEleven๐Ÿ‘ I need to do rear pads, and was just going to use the 'app' to fully open the EPB, and then the 'app' again to close/reset the EPB. Do you both think this is a bad idea, and that I should code them open and closed? I guess the 'apps' are coded by the bod's at OBDEleven? So I assumed (maybe incorrectly) that they would know what they're doing, and so less chance of me screwing something up by pressing something I shouldn't and getting it wrong ?
  6. Had my under bonnet sound/heat/insulation pad replaced today, under warrenty. Took all of 15mins! Hats off again to Windrush Maidenhead.
  7. I did think about buying VCDS when I brought the new updated IOS OBDEleven, maybe I should have. ๐Ÿ™„ Do you find using VCDS very user friendly? It was only the easiness of using the Apps on OBDEleven that swayed me to OBDEleven.
  8. I have success...... Deleted the app, reinstalled it...... It now seems to working....๐Ÿ˜Š Many thanks for all assistance.๐Ÿ‘
  9. Thanks.๐Ÿ‘ Yes, running the latest IOS update, what ever that maybe! I'll delete the app, then reinstall it tomorrow, and see if that sorts it.
  10. That's a good call.๐Ÿ‘ I'll give it a try tomorrow.
  11. Thanks๐Ÿ‘ I just need to find the old Android only one....................๐Ÿ™„
  12. You're a โญ, thanks so much for trying. ๐Ÿ‘ Got it new, direct from OBDEleven, ordered it Nov '20. So got to work early this morning, cleared out the workshop, put car in, closed the doors, put the heater on, and thought i'm going to get this thing working....... After 45 mins of trying, couldn't even get the damn thing to connect............... Strong WiFi signal, or via a strong 4G signal. Plug it in, it lights up red, press connect, put my 6 digit code in, in then flashes or pulses a white light, and the app is just stuck on 'connecting' Tech really isn't my fortay..... Have contacted OBDEleven, will just have to wait for their responce............... Yes, I have the Pro version, I'll need to hunt for my old Android one........and the old Android phone, ๐Ÿ™„ try that, if it works, then look for the coding sequence. Thanks again for taking the time out this morning๐Ÿ‘
  13. Do you know if the new version is both Android and IOS?
  14. Thanks, that would be a massive help if you manage to get the time.๐Ÿ‘ I'll have another play tomorrow. Then garage hunting for my old Android one.....๐Ÿ™„
  15. Evening all,๐Ÿ‘‹ Finally got around to connecting my new OBDEleven, IOS version. Connected, updated, put in password, collected my 100 free credits, all ok. However, all the apps come back with 'Not Supported' Car is '18. Have used the older Android one, without any problems, and all my previous changes are listed in the OBDEleven App on my IPhone. Just wondering if anyone else has had the same issue / problem. Will need to go hunting in the garage to find the older Android one, and see if that still works, as I need to do the rear disc's and pads......... Thanks in advanced๐Ÿ‘
  16. So it's been a couple of weeks since getting these fitting, and have racked up a few miles. So far, I only have good things to report ๐Ÿ‘ As good, if not better that the Michelins in damp / wet conditions, however, the Michelins may be a little better in the dry. Can't comment in warmer conditions, as it's Autumn !! Just my opinion so far.........
  17. That steering wheel is something else, May I ask where you got it from?
  18. Will do ๐Ÿ‘ I'll put a few miles on them and report back.๐Ÿ™‚
  19. New boots fitted. Decided to throw caution to the wind, buck the trend and be different. So got 4 x Goodyear Eagle F1 Asymmetric 5's fitted. Will see how they feel compaired to the Continental and Michelin set's I've had before.
  20. I'm sure you always show them that the Force is stronger with the R !!!!๐Ÿ˜
  21. A bit late, but glad you've got it all sorted๐Ÿ‘
  22. Not GTI drivers, but Fiesta ST drivers.................๐Ÿ™„
  23. Done mine yesterday. Picked up new battery from Screwfix. All ok.๐Ÿ‘
ร—
ร—
