Showing results for tags 'lowering springs'.
Found 4 results
  1. Has anyone managed to change the lowering springs and willing to share a guide, tutorial or video they followed? I'm quite hands on mechanically with cars but need a guide to follow for correct torque specs etc Kindly let me know, thanks!
  2. Hi, bought set of Prosport coilovers for my 2011 Passat CC, and looking to see if anyone knows anything about installing them with the DCC suspension. Will faults show up on car? Will it cause issues with the suspension? Does it have to be recalibrated? Etc. Local Mechanic says messing with the suspension in the car will also effect the lights as they move with the car, and would it just be easier installing lowering springs, assuming the springs will only effect the ride hight. Thanks in advance
  3. Hello all, my first post on the forum. Just wondering: Which are the ‘best’ lowering springs for ride comfort? The car won’t be getting track use so I’m just looking to reduce the arch gap, without breaking my back 😂. With that in mind, I’m looking at a 20mm drop. Which spacers are best, that don’t cause rub? Should also note; - I won’t be changing the dampers on the car. - I’m running the 18inch Pretoria’s. As opposed to the 19’s or the Cadiz.
  4. Hi guys, I'm brand new as a member but i've been reading VWROC for some time now! I currently have a MK7 GTI in pearl black... It's a lovely car... But it was time for an upgRade! I placed an order for a 3door DSG R in Limestone Grey Metallic with a few other extras - should get here for the end of the year (just in time for the salt and snow! ) I was wondering what performance and exterior modifications you guys have made? My plan is: - ECS tuning drilled & slotted 2-piece, semi-floating brake rotors - VWR lowing springs - 10/15mm wheel spacers - 19" VWR 360 alloy wheels (machine finished) - APR stage 1 re-map (after running in period) - VWR 600 air intake kit - UK number/license plate holder not to be fitted! - specifically asked the dealer not to have the unsightly black mount fitted to the front bumper as I'll be using a private plate and velcro fixings. - Gloss black VW badges with LSG inserts - Gloss black front headlight eyelids - Gloss black 3M roof wrap - Gloss black 3M front lip wrap (middle section in line with the grill) - Gloss black 3M wrap continuation of front ducts - Carbon fibre front canards (as below) Below are some images of my current car, and images that have given me ideas for the new R - please let me know what you think and share your pictures! Cheers! Chris https://www.instagram.com/p/BH9JbXKjvtu/ my car https://www.instagram.com/p/BlpheN8jJdu/ my car again https://www.instagram.com/p/BKglPejfbM/ gloss black wraps, eyelids and canards http://www.racingline-performance.com/r360-alloy-wheel potential new wheels in machined finish https://goo.gl/images/0H59t9 LSG with no front number/ license plate https://www.ecstuning.com/News/Volkswagen_MK7_Golf_R_GTI_ECS_2_Piece_Rotors_010516/ES2972827/ ECS brakes not sure how to upload images directly... that would be a lot easier!
