drl brightness
dazie00
This setting is for the DRL dimming when side lights are selected. At the factory setting its too dim but p[lease note 100% is too bright for night use (in towns with street lighting of course) and you will be dazzling other road users. Around 50% works very well.
It also adjusts the brightness whilst main beam is on - meaning you can see the uu more clearly.
Its somewhere around 60% i think. I found there was quite a differenece between about 50 and 60 for some reason.
Have you got codes for inner brakelights, still struggling on that 1!
ive put it to 100% for now but can see it coming down from there !
  1. 9 - Central Electronics
  2. 16 -  (security code 31347)
  3. 10 - Adaptations
  4. Change [8] Leuchte23sl HLC10 - Lichtfunktion C23 from Not Active to Brake Light
  5. Change [10] Leuchte23sl HLC10 - Dimmwert CD 23 from 0 to 100
  6. Change [8] Leuchte24sl HRA65 - Lichtfunktion C24 from Not Active to Brake Light
  7. Change [10] Leuchte24sl HRA65 - Dimmwert CD 24 from 0 to 100
