Folding Mirrors Issue
th3_f15t
I'd of thought the switches were the same regardless. Like I said, the mirror position adjust works fine, so when doing the driver's side it's in the R position ect.
My problem with the coding now is the other fields that my tool allows me to edit...
Component - Tuer-SG*** (This changes depending on the values below)
Soft. Coding (As provided, hopefully)
WSC (Assume this is Work Shop Code)
IMP (Import number, whatever that is)
Device (Not really got a clue here...)
If I know exactly what values to add in here, maybe I can get them fully coded to work as Mk6 Golf 5 door front modules.
  • 3 months later...
The plot thickens... So I've chucked in the codes provided and reset everything, so I'm pretty confident to say my coding and software is now all sorted. However, under some further testing I've discovered this (bare with me here)...
When the switch is in the Heated mirrors position, I get a reading that the switch is in Folded In position, the passenger mirror folds in but the drivers mirror folds out:
When I put the switch into the Folded In position, I get a reading that the switch is in Heated position, the passenger mirror folds out but the drivers mirror folds in:
The other positions (Left, Off and Right) all work and report back correctly, it's just the top two functions that are wrong. I'm convinced some wires need switching around, anyone got the faintest of ideas?
just a bit of a write up might help
The retro fit is easy but it is a huge list of very expensive parts starting with the mirror units at £214.30 a side plus the cap and glass often break when being removed, especially the cap retaining tags. What you want is PR-6XP and the window regulators motors only appear to be different for cars with folding + memory + anti dazzle. A violet and a blue wire have to be added between the window regulator and the mirror. Then you need a new drivers side switch but the wiring appears to be there for that function so then just recoding of the door control unit. The usual retro fit companies don't appear to offer a kit which is odd.
good read on here also
http://www.vwaudiforum.co.uk/forum/showthread.php/160106-Power-folding-wing-mirrors
Further to my last, noticed that the coding may be slightly wrong looking at the image provided on this post (thanks PND), think my codes should be:
Drivers Door - 4782
Passenger Door - 5038
I'll give these a go and report back!
