th3_f15t Posted December 22, 2015 Report Share Posted December 22, 2015 I have some issues since fitting electric power folding mirrors on my mk6 Golf. The details of all the faults: Window switches from the front doors at totally reversed, so driver's down does passenger side up ect. Rear window controls are up/down reversed (but sides are correct so driver's does driver's) Driver's side mirror & puddle light don't work (doesn't fold in/out) but the adjustment of the mirror glass works Mirror controls switched sides and controls for up/down are now left/right and left/right does up/down Passenger mirror folds in when switch is in normal position and folds out when in the folded in position I do have an error code that won't clear, which I'll post up later over this line of text. The strange thing is, when I run an active test on the passenger door (using my diagnostic tool, a Foxwell NT500), it actually operates the passenger door (so inputs to features aren't reversed in sides like they are through the switches in the driver's door). However, the actions are reversed so when it was winding the windows up they went down and when it folded the mirror in, it folded out. I did grab the coding from each door module too, but I'm unsure whether they are actually for the right sides as the fault was an electric one with the passenger mirror but it's the driver's side that shows the symptoms of electrical issues. Anyone able to help me out??? I just wanted to add some optional extras, I'm no retro fitter (clearly!). Quote Link to comment Share on other sites More sharing options...
th3_f15t Posted December 22, 2015 Author Report Share Posted December 22, 2015 OK, lets add some details to help out here... All scans are taken from my diagnostic tool (Foxwell NT500) so please excuse the lack of VCDS-formats.Driver's Door Details:Vehicle: /scan/VAG/Test Path: VW, Models (Guide Function), 5K - Golf 2009 >, 2012 ©, Sedan, CDLF 2.0 L Motronic / 199kW, 02-Auto Trans, Read Codes, 42-Door Elect, Driver, Read Codes, ECU Information, Live Data, Active Test, 46-Central Conv., 52-Door Elect, Pass., Read Codes, ECU InformationECU InformationVAG Number 1Q0959702HComponent Tuer-SG0092113Soft. Coding 0020918WSC 000020IMP 0556Device 0000006Vehicle: /scan/VAG/Test Path: VW, Models (Guide Function), 5K - Golf 2009 >, 2012 ©, Sedan, CDLF 2.0 L Motronic / 199kW, 02-Auto Trans, Read Codes, 42-Door Elect, Driver, Read Codes, ECU Information, Live Data, Active Test, 46-Central Conv., 52-Door Elect, Pass., Read CodesRead Codes00830 Convertible Top Control Module (J256) - sporadic 004-No Signal/Communication Passenger Door DetailsVehicle: /scan/VAG/Test Path: VW, Models (Guide Function), 5K - Golf 2009 >, 2012 ©, Sedan, CDLF 2.0 L Motronic / 199kW, 02-Auto Trans, Read Codes, 42-Door Elect, Driver, Read Codes, ECU InformationECU InformationVAG Number 5K0959701GComponent Tuer-SG0092101Soft. Coding 0000180WSC 001357IMP 0022Device 0001600First thing I notice is looking at the scan paths, it appears that the driver's door is being read as the passenger door and vice versa. This would explain why the fault for no communication to the mirror appears on the passenger side although it's the driver's side that is the issue.Should I swap the coding, WSC, IMP and Device numbers over with each other as a first port of call? Also aware that I'll need to swap the + and - wires around, think it's wires 14 and 15 from reading another post but anyone with a diagram or can tell me which colours I need to swap would be legendary! Quote Link to comment Share on other sites More sharing options...
TechieAli Posted December 23, 2015 Report Share Posted December 23, 2015 My Mk6 GTD had electric folding mirrors here are the coding's from it. It was a 5 door. I hope this might help you. Actually re-reading it, you have got your drivers and passenger doors the wrong way round. Driver's Door Details:Vehicle: /scan/VAG/Test Path: VW, Models (Guide Function), 5K - Golf 2009 >, 2012 ©, Sedan, CDLF 2.0 L Motronic / 199kW, 02-Auto Trans, Read Codes, 42-Door Elect, Driver, Read Codes, ECU Information, Live Data, Active Test, 46-Central Conv., 52-Door Elect, Pass Passenger side.., Read Codes, ECU Information Passenger Door DetailsVehicle: /scan/VAG/Test Path: VW, Models (Guide Function), 5K - Golf 2009 >, 2012 ©, Sedan, CDLF 2.0 L Motronic / 199kW, 02-Auto Trans, Read Codes, 42-Door Elect, Driver Drivers side, Read Codes, ECU Information -------------------------------------------------------------------------------Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl Part No SW: 5K0 959 701 C HW: 5K0 959 701 C Component: Tuer-SG 009 2114 Coding: 0004790 Shop #: WSC 01357 011 00200 VCID: 3261E198ADDB668E5D3-8067 No fault code found. -------------------------------------------------------------------------------Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl Part No SW: 5K0 959 702 C HW: 5K0 959 702 C Component: Tuer-SG 009 2114 Coding: 0005046 Shop #: WSC 01357 011 00200 VCID: 336FE49C52C16F86565-8066 No fault code found. -------------------------------------------------------------------------------Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl Part No SW: 5K0 959 703 C HW: 5K0 959 703 C Component: Tuer-SG 007 2101 Coding: 0000144 Shop #: WSC 01357 011 1012552 VCID: 346DE78057CF68BE4FF-8061 No fault code found. -------------------------------------------------------------------------------Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl Part No SW: 5K0 959 704 C HW: 5K0 959 704 C Component: Tuer-SG 007 2101 Coding: 0000144 Shop #: WSC 01357 011 1012552 VCID: 356BDA845CB571B6781-8060 No fault code found. Thinking about the error code, in the gateway do you have a convertible roof module? and do you have a convertible? If you don't them untick the convertible roof module in the gateway coding. Module 19. Quote Link to comment Share on other sites More sharing options...
th3_f15t Posted December 23, 2015 Author Report Share Posted December 23, 2015 I don't have a convertible, nor do I have VCDS but your support is still massively appreciated! I think I may try swapping the modules around at the weekend to see if that solves a lot of the issues, then chuck the coding in you provided here and see where I am after that. Another thought is that the passenger module (which is possibly the one in the door) has a code of 180 which would imply very little of the features are active so this may explain the lack of folding and LED puddle light... Here's to hoping anyway! Quote Link to comment Share on other sites More sharing options...
TechieAli Posted December 23, 2015 Report Share Posted December 23, 2015 Note your door modules have different part numbers to. Quote Link to comment Share on other sites More sharing options...
th3_f15t Posted December 23, 2015 Author Report Share Posted December 23, 2015 Hence why I'm going to swap my modules around, move the driver's one to the passenger side then re-test and see where I'm at. I thought I was careful when matching part number but must of got confused! I've read a few other posts where people have put the modules in the wrong doors and ended up with reversed controls. Did you folding mirros also have puddle lights, dipping the passenger when in reverse and heating as well? Quote Link to comment Share on other sites More sharing options...
toosmiles Posted December 23, 2015 Report Share Posted December 23, 2015 Hence why I'm going to swap my modules around, move the driver's one to the passenger side then re-test and see where I'm at. I thought I was careful when matching part number but must of got confused! I've read a few other posts where people have put the modules in the wrong doors and ended up with reversed controls. Did you folding mirros also have puddle lights, dipping the passenger when in reverse and heating as well? ive got folding mirrors(only off button on door) i think sometimes off key fob lol also puddle lights and dipping reverse m8 now ive got vcds also and willing to try and get some logs etc if that helps mike? Quote Link to comment Share on other sites More sharing options...
th3_f15t Posted December 23, 2015 Author Report Share Posted December 23, 2015 If you mirrors support all the features that mine are after, getting a copy of the software coding numbers would be great, just to check whether yours and TechieAli are the same, thus meaning they are the ones I need. Quote Link to comment Share on other sites More sharing options...
th3_f15t Posted December 26, 2015 Author Report Share Posted December 26, 2015 So I switched my modules around today and it's made things worse! I know only have the driver's window control (still up/down reversed) but no other swtiches work. Doors now unlock the wrong way round and the lights within the doors don't work at all. But both my mirrors are now folded out... chris_blue 1 Quote Link to comment Share on other sites More sharing options...
TechieAli Posted December 26, 2015 Report Share Posted December 26, 2015 Interesting did you scan again? Quote Link to comment Share on other sites More sharing options...
PND Posted December 26, 2015 Report Share Posted December 26, 2015 Here's the log off mine - 5dr 2012 mk6 R with retrofitted folding & heated mirrors with puddle lights and I've also got retrofitted door warning lights in the bottom of all 4 doors. I'm trying to find the full list of which bits to tick for which options, that gives you the coding. If I locate it later on, I'll stick it on here for you. Hope it helps! ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl Part No SW: 5K0 959 701 E HW: 5K0 959 701 E Component: Tuer-SG 009 2140 Coding: 0004854 Shop #: WSC 01357 011 00200 VCID: 3449D2485702F881BA7-8061 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl Part No SW: 5K0 959 702 C HW: 5K0 959 702 C Component: Tuer-SG 009 2114 Coding: 0005110 Shop #: WSC 01357 011 00200 VCID: 334BD154520CFFB9A3D-8066 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl Part No SW: 5K0 959 703 D HW: 5K0 959 703 D Component: Tuer-SG 007 2101 Coding: 0000208 Shop #: WSC 01357 011 1012551 VCID: 354FEF4C5C78E1898D9-8060 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl Part No SW: 5K0 959 704 D HW: 5K0 959 704 D Component: Tuer-SG 007 2101 Coding: 0000208 Shop #: WSC 01357 011 1012551 VCID: 364DE840417EEA91843-8063 No fault code found. Quote Link to comment Share on other sites More sharing options...
th3_f15t Posted December 26, 2015 Author Report Share Posted December 26, 2015 Thanks guys. I switched the modules back about and where I had messed about with the coding it now mostly works. The window switches work as they should, doors unlock properly and the indicators work. However, the mirrors both fold in when the switch is on any other position other than the folded in position, and up/down moves the mirror glass left/right (rotated controls 90 degrees anti clockwise effectively). Interestingly, the switch doesn't fit into the door handle like the original one did, suspect I have a non-OE one which is poorly made so may source a second genuine one and see. Also, my passenger door thinks it's a cabrio, as when you open the door or turn the engine off, the window drops a few centimetres and I get an error code relating to the roof motor all the time. Other than that I get no fault codes. I think what I need to do now is get hold of VCDS and code it properly as my diagnostic tool doesn't quite code in the same way as VCDS does so it's very difficult to work out the correct values for all of the fields. Quote Link to comment Share on other sites More sharing options...
chris_blue Posted December 26, 2015 Report Share Posted December 26, 2015 Reminds me of a laurel n hardy film.....;-) How the music go...... Quote Link to comment Share on other sites More sharing options...
PND Posted December 26, 2015 Report Share Posted December 26, 2015 Not my image, but may be of use.. Not sure how I actually ended up at some of my settings, but mine seem to work fine. Driver side coding = 0004854 - which is made up of 2 + 4 +16 + 32 + 64 + 128 + 512 + 4096 = 4854. Passenger side coding = 0005110 - which is the same as above + 256 (not sure why!). I don't get any errors with these settings so am happy to leave them as they are! Good luck! Quote Link to comment Share on other sites More sharing options...
TechieAli Posted December 27, 2015 Report Share Posted December 27, 2015 The 256 is probably for the dipping mirror when the switch is in the L position and you put it in reverse. the3_f15t - Maybe you have a left hand side switch, rather than a right hand side switch. Quote Link to comment Share on other sites More sharing options...
