Setting inter brake lights issue
Jeff R
When trying to set my inter brake lights, I'm faced with a problem, the guide suggests I should find 'brake lights on' then adjust the setting from 0-100, but when using 15.7.3 vcds & selecting the correct lines of code, the only option that's bake related is 'brake lights' not 'brake lights on' and it won't accept this 'brake lights'
It comes up as out of range
Any help please?
I'm using genuine vcds version 15.7.3 & a genuine Ross tech cable
I did mine using the below info which neg gave me, I also had trouble at first sure I selected some setting in the first part that said brake active or Aktiv 100%, but it was over a year ago since I did it and my memory's not what it used to be.
Two part, 1, enable the lights
09 (Central Electronics)
Security Access - 31347
Adaptation Channels
(8) - Leuchte27 NSL RC6  -Lichtfunktion C27" > "Brake light on", Set
2, turn up the power from 0 to 100%
(10) - Leuchte27 NSL RC6 - Dimming CD27" > "100", Set
