Spinstorm Posted June 27, 2016 Author Report Share Posted June 27, 2016 I just followed the thread at the start. And your instructions. I do have a Discover Nav Pro and it is a MY2017 car. I don't know if that may make a difference or not. Quote Link to comment Share on other sites More sharing options...
Chriss5471 Posted July 25, 2016 Report Share Posted July 25, 2016 How do I do this using OBD11? From http://www.briskoda.net/forums/topic...7#entry4476927 Controller 5F (Information Electrical) 10 - Adaptations Select channel: (63) Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21 Adjust Value to activated Channel: (151) Car_Function_Adaptations_Gen2-menu_menu_display_road_sign_identification Adjust Value to activated Controller A5 (Front / front view camera) 07 - Coding Byte 1 Bit 0 Enable - "01 traffic sign recognition (FTE) active" Controller 17 (Instruments) 07 Coding Byte 5 Bit 2 Enable - "Traffic Sign Recognition installed" Controller 5F (Information Electr.) 07 - Coding Byte 24 Bit 6 - untick Traffic Sign Display (VZA) active Controller A5 (Front / front view camera) 07 - Coding Byte 16 Bit 4 - tick this box (currently there are no descriptions for A5 longcoding) Ok I have done this and have signs displaying however it would not let me do the last step: Controller A5 (Front / front view camera) 07 - Coding Byte 16 Bit 4 - tick this box (currently there are no descriptions for A5 longcoding) When I clicked to save after making this change it said that the change could not be made, any ideas why this may be? Quote Link to comment Share on other sites More sharing options...
Spinstorm Posted July 25, 2016 Author Report Share Posted July 25, 2016 It all worked for me. I did do it all manually using OBD11. I did a trial run to make sure I knew where everything was before I did it. I'd suggest maybe restarting the app and reconnecting and trying that last step again. I assume of course you have the camera for lane assist... Quote Link to comment Share on other sites More sharing options...
Chriss5471 Posted July 26, 2016 Report Share Posted July 26, 2016 It all worked for me. I did do it all manually using OBD11. I did a trial run to make sure I knew where everything was before I did it. I'd suggest maybe restarting the app and reconnecting and trying that last step again. I assume of course you have the camera for lane assist... Yea I think the only options I didn't tick were a sunroof, leather and DCC! It's weird as all steps worked fine until I got to the last one which just wouldn't work, however the traffic sign recognition is now working. Do we know what Byte 16 Bit 4 is meant to be enabling? Quote Link to comment Share on other sites More sharing options...
Spinstorm Posted July 26, 2016 Author Report Share Posted July 26, 2016 I have no idea. I just followed the instructions. I'm not an expert at coding in any way whatsoever. Maybe someone else can tell us? Sent from my iPhone using Tapatalk Obbzi 1 Quote Link to comment Share on other sites More sharing options...
NicCo Posted December 16, 2017 Report Share Posted December 16, 2017 Hi, Thank you for this how to. Could you confirm Byte 24 bit 6 must be unticked and no ticked ? Thank you ! Quote Link to comment Share on other sites More sharing options...
NicCo Posted December 18, 2017 Report Share Posted December 18, 2017 The Byte 24 bit 6 must be ticked, without it Sign Assist menu doesn't appear on both displays, just sign at the top : Controller 5F (Information Electr.)07 - CodingByte 24 Bit 6 - untick Traffic Sign Display (VZA) active Quote Link to comment Share on other sites More sharing options...
