Roots Supercharger Posted August 20, 2016 Report Share Posted August 20, 2016 Is there a VCDS mod that will allow constant full instrument illumination with the ignition switched on but the light switch turned off? Quote Link to comment Share on other sites More sharing options...
VW R-300 Posted August 20, 2016 Report Share Posted August 20, 2016 I believe it's a photovoltaic sensor turning the instruments lights on and off dependent on lighting. I'm sure there's coding to disable this Quote Link to comment Share on other sites More sharing options...
Rich_D Posted August 20, 2016 Report Share Posted August 20, 2016 Have a look in here >>> http://www.vwroc.com/forums/topic/14338-instrument-cluster-backlighting-with-sidelights-on/ Quote Link to comment Share on other sites More sharing options...
dv52 Posted August 20, 2016 Report Share Posted August 20, 2016 ^^ ^^ Instrument cluster illumination on a mk7 is "physically" controlled by a phototransistor that you can just barely see in the tacho dial between the "7" and "8" position (it looks like a feint circle that is embedded in the background clock-face). It's controlled "virtually" by a group of adaptation channels with the descriptor "dimming_characteristic_curve_adjustment" that reside in the control module @ address hex17 . By changing these settings, the dash lighting can be made to do nearly anything! But (and there is always a "but"), a valid security access code is needed to access these settings in the Instrument control module. For mk7 models up to MY16, the code 20103 is successful. However for MY16 vehicles and forward, it appears that this code is not valid and as I understand, a replacement code has not yet been found. Happy to be proven wrong - please post the new security code if you know it (it's not 25327) So, if your mk7 is pre MY16, you can find a couple of options in the "instrument" category of my VCDS reference thread (see link below). If you just want the speedo and tacho dials to become brighter in daylight, I suggest that you try the tweak by ZEAL8080. If you have tinted the car's windows (this causes the dash lights to dim), or if you want the entire dash to be brighter (including the infotainment screen in the MIB unit), then try my tweak. If you are an insomniac and you need something to make you sleep, or if you are a real "geek" and you want to read a fellow geek's guess of how the "dimming characteristic curve" might work, then you will find an explanation of my hypothesis in the How-to Guide ("Reference Resources" category) of the link below. Don http://www.vwwatercooled.com.au/forums/f197/mkvii-vcds-tweak-reference-thread-98034.html goRt, dazie00 and Rich_D 3 Quote Link to comment Share on other sites More sharing options...
ATGNI Posted August 22, 2016 Report Share Posted August 22, 2016 Do you mean the blue needles constantly on? Quote Link to comment Share on other sites More sharing options...
dv52 Posted August 23, 2016 Report Share Posted August 23, 2016 Do you mean the blue needles constantly on? ATGNI: Hi. No, ZEAL8080's tweak (I assume this is the tweak that you are asking about) doesn't change the behaviour of the "needles". The tweak will result in greater illumination of the two clock-dials (i.e. the scale on the tacho and the speedo dials). If you want the needles to be constantly ON, you should change the value of the code string for Byte 0, Bit 1 on the Instrument control module (@ address Hex17) as per the screen-shot below. Just to explain the descriptor on this Bit (in the screen-shot), Terminal 15 ON means ignition switched-on and Terminal 58 OFF means the dash lighting off - so, ticking this Bit turns-on the needle illumination when the ignition is switch-on even though the light switch is off!! Don XaGiCo 1 Quote Link to comment Share on other sites More sharing options...
