Mat Posted December 1, 2016 Report Share Posted December 1, 2016 I've got the DLA options on my car, and it was always a pain to switch on the HBA mode every morning.... So, I did a search and found out how to make HBA always on. And lo and behold, here we go ! high beam assist to stay on permanently Controller 09 - Central Electronics 16 - Security Access - enter 31347 10 - Adaptations • (5)-Assistenzlichtfunktionen-Fernlichtassistent Reset • Wert anpassen: "nicht aktiv" [standard = "aktiv", d.h. Fernlichtassistent bei "Zündung aus" deaktiviert] By doing this, if your light-switch is in the Auto position when you start the car, HBA will be automatically enabled (White headlight symbol on the dash). (rough translation is: • Adjust value to: "not active" [default = "active", i.e. High-beam assistant deactivated with "Ignition off"]. - in other words, this stops HBA being reset to off when the ignition is switched off) Booth11 1 Quote Link to comment Share on other sites More sharing options...
TheBlondeFella Posted December 1, 2016 Report Share Posted December 1, 2016 any idea how to turn it off permanently? Quote Link to comment Share on other sites More sharing options...
Mat Posted December 1, 2016 Author Report Share Posted December 1, 2016 "In module 09 (Centr. Elec.) byte 11 bit 3 needs to be on (enable the high beam assist)". so I reckon, if you don't have that bit enabled, it may turn off HBA functionality. Might be worth a shot..... I can't try it on mine anyway, as I've got DLA, and that might be different. Quote Link to comment Share on other sites More sharing options...
gjamesm Posted November 12, 2017 Report Share Posted November 12, 2017 On 2016-12-01 at 10:14, TheBlondeFella said: any idea how to turn it off permanently? You can turn it off in the vehicle settings. Quote Link to comment Share on other sites More sharing options...
TheBlondeFella Posted November 12, 2017 Report Share Posted November 12, 2017 5 hours ago, gjamesm said: You can turn it off in the vehicle settings. How? I can't see any options to do this in the settings. What year is your car? Quote Link to comment Share on other sites More sharing options...
