gigolo456 Posted December 19, 2016 Report Share Posted December 19, 2016 Hi Folks, I'm clearly still getting used to my R, plse forgive me!! Is it called Coming Home Lights when you unlock the car in the dark and the headlights automatically come in? Had this in my Mk V GTi, but for the life of me they don't come on in my R, do I need to set this up via the Infotainment Menu? Cheers Andrew Quote Link to comment Share on other sites More sharing options...
jimmy_uk Posted December 19, 2016 Report Share Posted December 19, 2016 Yes the option needs switching on in the infotainment (hate that word) system. The lights also need to be switched to Auto otherwise it's just the DRLs that come on. Quote Link to comment Share on other sites More sharing options...
gigolo456 Posted December 19, 2016 Author Report Share Posted December 19, 2016 So if you manually switch off the headlights, the full headlights will never come on when you unlock the car? Are the DRL's the side lights? Quote Link to comment Share on other sites More sharing options...
jimmy_uk Posted December 19, 2016 Report Share Posted December 19, 2016 That's correct, unless they are in Auto they won't come on when you unlock. The DRLs are the double u shaped lights in the headlight assembly. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted December 19, 2016 Report Share Posted December 19, 2016 Are the DRL's the side lights? As above, and DRL can't be turned off, unless you use VCDS, as they are a legal requirement. Quote Link to comment Share on other sites More sharing options...
AD_RX8 Posted December 19, 2016 Report Share Posted December 19, 2016 That's correct, unless they are in Auto they won't come on when you unlock. The DRLs are the double u shaped lights in the headlight assembly. Iv got a my17 R and my DRL don't come on when I unlock the car, only the full headlights when its on 'auto', are the DRL meant to come on if its not on 'AUTO'?? Quote Link to comment Share on other sites More sharing options...
jimmy_uk Posted December 19, 2016 Report Share Posted December 19, 2016 The DRLs do on my 16 plate R, and did on my 14 plate GTD if the switch is in off. They also come on with the headlights when the switch is in auto. The DRLs and headlights only come on though if the option is enabled in the menus, and, of course, it's dark. AD_RX8 1 Quote Link to comment Share on other sites More sharing options...
