Lawrie Posted February 25, 2017 Report Share Posted February 25, 2017 Automatic Coming Home Lights - Verified working on 2014 - 2017 pre-facelift Rs 1) Go to Central Electrics 2) Then security and enter 31347 3) Go to Adaptation 4) Select Comfort Illumination 5) Change coming home verbaustatus from manual to automatic 6) Click the green tick to confirm Booth11 1 Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 10, 2017 Report Share Posted June 10, 2017 So what exactly does this do, just leaves the lights on when locking the car?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 10, 2017 Report Share Posted June 10, 2017 4 hours ago, slider09 said: So what exactly does this do, just leaves the lights on when locking the car? Sent from my iPhone using Tapatalk It automatically activates the lights to stay on for a brief period of time once you have turned ignition off and exited the car (with lights switch on Auto), rather than the standard method of having to pull the indicator stalk towards you after ignition off and before opening the door. Additionally you need to make sure you have Leaving Home and Coming Home lights enabled in the CAR settings on infotainment unit, set at 20 seconds or so. slider09 1 Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 10, 2017 Report Share Posted June 10, 2017 It automatically activates the lights to stay on for a brief period of time once you have turned ignition off and exited the car (with lights switch on Auto), rather than the standard method of having to pull the indicator stalk towards you after ignition off and before opening the door. Additionally you need to make sure you have Leaving Home and Coming Home lights enabled in the CAR settings on infotainment unit, set at 20 seconds or so.I've enabled this but it's not working. Just been out to check the settings on the infotainment unit and it was set at 10 secs.Does it need to be set at 20 secs minimum for it to work? I've changed to 20, will nip out when it gets darker, see if it works. Thanks Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 10, 2017 Report Share Posted June 10, 2017 10 minutes ago, slider09 said: I've enabled this but it's not working. Just been out to check the settings on the infotainment unit and it was set at 10 secs. Does it need to be set at 20 secs minimum for it to work? I've changed to 20, will nip out when it gets darker, see if it works. Thanks Sent from my iPhone using Tapatalk I don't think the number of secs makes a difference, but you may be experiencing what I did when I first coded them - you need to have had the engine running prior to switching ignition off and closing doors/locking and it needs to be dark. Also make sure your lights are set to Auto. I had problems at first but it's because I was checking them without having been running the engine. Have a read as of this thread from this post on. slider09 1 Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 10, 2017 Report Share Posted June 10, 2017 Have a read as of this thread from this post on. This link doesn't work for me?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 10, 2017 Report Share Posted June 10, 2017 This link doesn't work for me? Sent from my iPhone using Tapatalk Are you on tapatalk? Does it work now? Post #15 onwards. http://www.vwroc.com/forums/topic/18416-obd-eleven/#comment-308614 Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 10, 2017 Report Share Posted June 10, 2017 Are you on tapatalk? Does it work now? Post #15 onwards. http://www.vwroc.com/forums/topic/18416-obd-eleven/#comment-308614 Sent from my iPad using Tapatalk Yes on Tapatalk and no, still doesn't work. I'll try through a web browser. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 10, 2017 Report Share Posted June 10, 2017 Yes on Tapatalk and no, still doesn't work. I'll try through a web browser. Sent from my iPhone using TapatalkWeird, works for me in tapatalk. Hopefully pasting it into web browser will work. Sent from my iPad using Tapatalk slider09 1 Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 10, 2017 Report Share Posted June 10, 2017 Weird, works for me in tapatalk. Hopefully pasting it into web browser will work. Sent from my iPad using TapatalkCopy and paste didn't work either. Had to log onto VWROC through safari and click on the link there. I'll wait until dark and start car for a minute, then see if it works. Thanks for your help Sent from my iPhone using Tapatalk Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 10, 2017 Report Share Posted June 10, 2017 Copy and paste didn't work either. Had to log onto VWROC through safari and click on the link there. I'll wait until dark and start car for a minute, then see if it works. Thanks for your help Sent from my iPhone using TapatalkHope it works for you, let us know how it goes. Sent from my iPad using Tapatalk slider09 1 Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 10, 2017 Report Share Posted June 10, 2017 Hope it works for you, let us know how it goes. Sent from my iPad using TapatalkAll good now, as you suspected it was just because I hadn't had the engine running when I tried it last (always have lights set to auto so knew it wasn't that. Thanks again. Sent from my iPhone using Tapatalk Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 10, 2017 Report Share Posted June 10, 2017 4 minutes ago, slider09 said: All good now, as you suspected it was just because I hadn't had the engine running when I tried it last (always have lights set to auto so knew it wasn't that. Thanks again. Sent from my iPhone using Tapatalk Great. 👍 It's a small mod but find it quite useful on a dark driveway. Quote Link to comment Share on other sites More sharing options...
CRZ13 Posted November 1, 2018 Report Share Posted November 1, 2018 Thought I'd resurrect this thread instead of starting a new one, does anyone know how to get the rear number plate lights to stay on with coming home lights after the car has been locked? Both inner boot lid tail lights and number plate lights go off when I lock the car, but the headlights and outer tail lights stay on. I've used VCDS to enable the inner boot lid tail lights to stay on with coming home lights after lock, but don't know the setting for the registration lamps. Any help is much appreciated! Quote Link to comment Share on other sites More sharing options...
KT600 Posted November 15, 2018 Report Share Posted November 15, 2018 Hi all. Just tried to set this up on my golf gtd. Started car. Light settings set at 10 seconds for come home and welcome Light switched set to auto . Switched ignition off. Flashed main beam Locked car Lights stayed on for 10 seconds . Tried this a few times. Headlights only come on when i unlock the car , not when i lock it So am assuming every time i want headlights to stay on before i lock the car is to flash the headlamps via the main beam stalk? Or program via obd11 etc? Thanks all Quote Link to comment Share on other sites More sharing options...
