Warning light
Betts-4
  • Replies 8
Obviously not normal.
Maybe have a quick look at the front radar sensor, make sure nothing stuck to it, or has hit it and knocked it out of alignment.
Believe if it needs realigning, it costs around £400 for some reason!!!
After 2 weeks if thats the case they can have the car back lol they best do it under warranty.If it can do that why does it not have protection I mean its a car that drives forward !!
Had this happen a few times. Would always do it at the start of my journey, driving down a dip in the road and turning right. Not sure why this manoeuvre would trigger the light. I just turned ignition off and back on and it cleared the warning light. This happened consistently for around 2 3 times a week. Hasn't happened for quite some time now. As suggested probably try cleaning the radar box... Ensure no debris.
Any fault code on the drivetrain (performance limiting) will trigger that error. VW had a spate of issues with camshaft position sensors which showed the exact same error. Only way to know the exact issue is to view the fault codes. Probably a dealer visit.
I had a slight boost issue, a pipe had come off/loose/not put on correctly. Would this have caused it with me?
