Head lights not working
Beast
Hi
have done a few mods with ths OBDEleven
1 Exhaust flaps etc
Did the change coming home to DRLs  but now which seemed to be ok but now noticed head lights (low, high and cornering lights not working)
The DRL are working ok
Come home light Automatic
Did the following
1) Go to Central Electrics
2) Then security and enter 31347
3) Go to Adaptation
4) Select Comfort Illumination
5) Change coming home verbaustatus from manual to automatic
6) Click the green tick to confirm
Change coming home lights to  DRL
1. Central electrics
2. Security Access 31347
3. Adaptions
4. Search Leuchte6ABL LC5 (left side low beam)
5. Select Lichtfunktion C 6
6. Change setting to Coming Home oder Leaving Home aktiv
7. Select Dimmwert CD 6
8. Change setting to 0
9. Select Dimming Directing CD 6
10. Change setting to minimize
11. Search for Leuchte7ABL RB1 (right side low beam)
12. Select Lichtfunktion C 6      Got this one wrong put C7
13. Change setting to Coming Home oder Leaving Home aktiv
14. Select Dimmwert CD 6        Got this one wrong put CD7
15. Change setting to 0
16. Select Dimming Directing CD 6
17. Change setting to minimize
I must have done something wrong
Can some one give me the default setting for the above
or can i reset all the central electric back to the default / basic setting
Help would be appreciated
Did this myself on the 7.5 this week...........with VCDS but I'd imagine this is same in OBD11
09 central electrics
Turn Off CH LH Low Beam
Left side Leuchte6ABL LC5        Lichtfunktion C6    change from not active to CH oder LH aktiv
                                                       Dimming Direction CD6 change from Max to Min
Right side Leuchte7ABL RB1     Lichtfunktion C6 change from not active to CH oder LH aktiv
                                                       Dimming Direction CD7 change from Max to Min
Turn on CH LH DRLs
Left side Leuchte2SL VLB10      Lichtfunktion G2 change from not active to CH oder LH aktiv
                                                       Dimmwert GH2 Change from 0 to 100
Right side Leuchte3SL VRB21   Lichtfunktion G3 change from not active to CH oder LH aktiv
                                                       Dimmwert GH3 Change from 0 to 100
Turn off CH LH Dot/Parking lights (Not needed on the 7.5)
Left side Leuchte4TFL LB4        Lichtfunktion G4 change from not active to CH oder LH aktiv
                                                      Dimming Direction GH4 change from Max to Min
Right side Leuchte5TFL RB32   Lichtfunktion G5 change from not active to CH oder LH aktiv
                                                      Dimming Direction GH5 change from Max to Min
Thanks go to DV52 for assisting with information too.
10 hours ago, Beast said:
Hi also note you have pedal box. Is it worth it cheers
Oh yes, I was a bit sceptical but saw 1 on here at a good price so went for it.
It makes eco mode feel more like normal and normal mode like race mode!
It just responds to throttle input so quickly it feels much faster.
There are 4 modes and 5 variations on each mode so 20 combinations to choose from and can change modes in seconds.
I find city mode ok for around town and sport mode for dual carriageway and motorway driving. Not yet decided on when to use sport + !
