RoryWelch Posted August 27, 2017 Report Share Posted August 27, 2017 Hi All - new to this forum! Ive got a Golf R Estate 7.5 turning up next month and have been looking into putting a JB4 box on instead of a custom/flash map. just interested to see what sort of figures people are seeing from the JB4 on the estate (or hatch) Thanks, Rory Quote Link to comment Share on other sites More sharing options...
Delta Posted August 27, 2017 Report Share Posted August 27, 2017 Hi Rory, congrats on your new R!. I don't have an estate mines a hatch I can tell you it will put a big smile on your face I'm on (JB4) map 2 with around 5.6psi more boost over stock. Where abouts are you I'm in Fareham Hampshire if your local I can take you for a spin if you like. Here is some info on the map settings. Map 0: Stock with complete pass through i.e. the JB4 does nothing Map 1: Tuned map with a average of 4.0psi over stock. This is the shipped map and is compatible for both 91 and 93 and can be used with cars on hardware. Map 2: This map is a more aggressive map. Peak boost add is 5.6psi over stock and the map is good for cars running 98Ron and above. Map 4: This is a stock map but with JB4 logging ability. It is also the starter map for cars that are running flash tunes and are stacking the JB4. It will give the ability to log the car via the JB4. This is also the safety map, so in any circumstance the JB4 detects a unsafe condition regardless of map it will default to this map. This includes knock detection, lean AFR or the boost safety value being triggered due to lack of boost control. Map 6: User adjustable boost map. The map comes preset with a 5.0psi over stock peak and is ready to use on any car running 93 octane. The preset map is also suitable for manual cars with clutch longevity in mind. The mapping can be done in two manners. If the value at 1500 is kept below 10 it will work as a boost adder map. If the value at 1500 is higher than 10 it will work as a absolute map. This means actual total boost targets will need to be entered. Map 8: Map three allows the JB4 to be the methanol controller working as a fail safe cutting boost if lack of meth flow is detected. You will require a Coolingmist FSB to get this working. User Adjustment page: Below is a outline of settings that can be changed in the User adjustment page: Map 6 (blue outline): as explained above Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
RoryWelch Posted August 27, 2017 Author Report Share Posted August 27, 2017 1 hour ago, Delta said: Hi Rory, congrats on your new R!. I don't have an estate mines a hatch I can tell you it will put a big smile on your face I'm on (JB4) map 2 with around 5.6psi more boost over stock. Where abouts are you I'm in Fareham Hampshire if your local I can take you for a spin if you like. Here is some info on the map settings. Map 0: Stock with complete pass through i.e. the JB4 does nothing Map 1: Tuned map with a average of 4.0psi over stock. This is the shipped map and is compatible for both 91 and 93 and can be used with cars on hardware. Map 2: This map is a more aggressive map. Peak boost add is 5.6psi over stock and the map is good for cars running 98Ron and above. Map 4: This is a stock map but with JB4 logging ability. It is also the starter map for cars that are running flash tunes and are stacking the JB4. It will give the ability to log the car via the JB4. This is also the safety map, so in any circumstance the JB4 detects a unsafe condition regardless of map it will default to this map. This includes knock detection, lean AFR or the boost safety value being triggered due to lack of boost control. Map 6: User adjustable boost map. The map comes preset with a 5.0psi over stock peak and is ready to use on any car running 93 octane. The preset map is also suitable for manual cars with clutch longevity in mind. The mapping can be done in two manners. If the value at 1500 is kept below 10 it will work as a boost adder map. If the value at 1500 is higher than 10 it will work as a absolute map. This means actual total boost targets will need to be entered. Map 8: Map three allows the JB4 to be the methanol controller working as a fail safe cutting boost if lack of meth flow is detected. You will require a Coolingmist FSB to get this working. User Adjustment page: Below is a outline of settings that can be changed in the User adjustment page: Map 6 (blue outline): as explained above Hi Mate, Thanks for the detailed response - gives me more of an understanding on the JB4 and what it's capable of? Im based in Essex so a fair way from you I think unfortunately! Quote Link to comment Share on other sites More sharing options...
Delta Posted August 27, 2017 Report Share Posted August 27, 2017 Essex that's a bit too far for a quick spin 😀 Quote Link to comment Share on other sites More sharing options...
RoryWelch Posted August 28, 2017 Author Report Share Posted August 28, 2017 12 hours ago, Delta said: Essex that's a bit too far for a quick spin Indeed it is 😂 Just debating whether I got JB4 or APR stage 1!! Quote Link to comment Share on other sites More sharing options...
Jon R306 Posted August 28, 2017 Report Share Posted August 28, 2017 Hi Rory Welch I'm driving a 7.5 hatch and yet to go JB4 but that's the way I'll go rather than Apr. I'm looking for a removable device for services visits etc. Quote Link to comment Share on other sites More sharing options...
RoryWelch Posted August 28, 2017 Author Report Share Posted August 28, 2017 18 minutes ago, Jon R306 said: Hi Rory Welch I'm driving a 7.5 hatch and yet to go JB4 but that's the way I'll go rather than Apr. I'm looking for a removable device for services visits etc. Yeah I get that! I have a local tuner so it's easy to remove/remap and I usually avoid any tuning boxes but the JB4 gets a good reputation so! Quote Link to comment Share on other sites More sharing options...
