OBDEleven coding - High Beam Assist
Benjamino69uk
This will only work on cars that are fitted with Lane Assist.
High Beam Assist (for cars with Lane Assist Camera):
Ensure light switch is in the OFF position, wipers not on auto, doors closed and ignition on, before starting.
1. Select Control unit 09 (Central Electrics)
2. Control unit Long Coding
3. Byte 02
4. Bit 0-2: "03 Lighting Bi-Xenon with Light Assist"
5. Select Control unit 09 (Central Electrics)
6. Security Access Code: 31347
7. Adaptation
8. Assistance Light Functions - Menuestuerung Fernlichtassistent
9. New Value: Present
10. Assistance Light Functions - Menuestuerung Fernlichtassistent Werkseinstellung
11. New Value: Present
12. Select Control unit A5
13. Security Access Code: 20103
14. Control unit Long Coding
15. Byte 02
16. Bit 0-7: "01 coding_Light/High_beam_assist"
Optional settings
17. Controller A5
18. Speed that HBA active set to 20kph
19. Speed that HBA deactivate set to 10kph
20. Change lux code to 10
Finally, go into the vehicle menu on the head unit, go to light settings and select ‘light assist’
Push the left stalk towards the front of the car, it should show the HBA logo at the bottom of the Maxidot.
Remember to select the Green tick at each step of the process!
  • 1 year later...
  • 2 months later...
Hi all I have a 2018 7.5 r and I took it to have the high beam assist activated and they couldn’t do it they said they couldn’t get into stm come back in 3 months were by which time there would be a patch and he would be able to do it is this the norm or should I try somewhere else ???
  • 3 years later...
Activated HBA for my spouse’s 2019 Tiguan
here are the steps:
Module 09 - Central Electric
Adaptation
Fernlicht
- Chose the line similar to the origins only with FLA
(For my S3 8V FL it was ueber AFS and not BCM
http://vwroc.s3.eu-west-2.amazonaws.com/monthly_2022_03/F074EE7A-F186-49B8-AE0D-1270F2A48823.thumb.jpeg.00a6c29e0c1052018f1454fdd1eb39bf.jpeg
Module A5 - driver assistance
Long Coding
http://vwroc.s3.eu-west-2.amazonaws.com/monthly_2022_03/73FA0BE2-E830-47E0-A7FC-CDB9BB25EDDC.thumb.jpeg.415292f228588660bb226eee8c0ef351.jpeg
