Aquanaute Posted September 11, 2017 Report Share Posted September 11, 2017 Not sure if my OBDelven dongle is faulty! Managed to get it to work yesterday to code the fan speed indication when in auto but when tried to do the exhaust flaps kept coming up with "device not responding" or "something went wrong". tried clearing the cache and also uninstall- reinstall the app. It connects and works with the solid red and flashing amber and green leds but then seems to freeze and only the red light is on. Got it to scan earlier and flashing leds until it got to the airbag module then only the red solid led. Is there anyone local in Norfolk with OBDeleven that could maybe try my dongle in tier car or theirs in my car to see which is faulty Any happy would be great. Quote Link to comment Share on other sites More sharing options...
slider09 Posted September 11, 2017 Report Share Posted September 11, 2017 My dongle is hit and miss. Sometimes will not connect at all. I find un-pairing the Bluetooth then re-pairing sometimes helps. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Aquanaute Posted September 11, 2017 Author Report Share Posted September 11, 2017 Tried that as well. It connects but then just seems to forget that its suppose to be doing something. Are the amber and green lights suppose to flash the whole time its communicating? Mine just stop after a while and then does nothing. Quote Link to comment Share on other sites More sharing options...
Amir7R Posted September 11, 2017 Report Share Posted September 11, 2017 I'd try it with ignition on and then again with engine on. Quote Link to comment Share on other sites More sharing options...
Aquanaute Posted September 14, 2017 Author Report Share Posted September 14, 2017 Moved the router out into the garage this morning and got it to connect long enough to do a full scan. Tried to long code the exhaust flaps but kept getting the error "value not changed" this was with ignition on and aslo the engine running, when trying to do anything after that just says "control module not responding". Does anyone else have an Autowatch Ghost fitted and use this to code without problems? Quote Link to comment Share on other sites More sharing options...
Amir7R Posted September 14, 2017 Report Share Posted September 14, 2017 13 minutes ago, Aquanaute said: Moved the router out into the garage this morning and got it to connect long enough to do a full scan. Tried to long code the exhaust flaps but kept getting the error "value not changed" this was with ignition on and aslo the engine running, when trying to do anything after that just says "control module not responding". Does anyone else have an Autowatch Ghost fitted and use this to code without problems? What "devices" are you exactly using? Quote Link to comment Share on other sites More sharing options...
Aquanaute Posted September 14, 2017 Author Report Share Posted September 14, 2017 Have tried it on my Samsung Galaxy S7 and also my Sony Z1 tablet. Quote Link to comment Share on other sites More sharing options...
Aquanaute Posted September 25, 2017 Author Report Share Posted September 25, 2017 Spoke with the tech support and was told to send it back to get it checked out and looks like its was faulty. Bit annoyed that they sent me a faulty dongle in the first place. They are sending me a new one but they won't refund the cost of me having to return the faulty one. Quote Link to comment Share on other sites More sharing options...
Aquanaute Posted September 28, 2017 Author Report Share Posted September 28, 2017 Replacement arrived yesterday and had chance to play with it today. Connected first time and managed to do a few codings so all good, thanks for everyones help trying to sort this. Quote Link to comment Share on other sites More sharing options...
