smk82 Posted October 1, 2017 Report Share Posted October 1, 2017 Could someone with VCDS take a look to see if there are any settings changable on the average fuel consumption as its annoying me at how long it takes to register things (i.e cruise at 50 for 25 mins and it barely shifts the average consumption at all), when compared to my wife's A1 which adjusts fairly fast..? Quote Link to comment Share on other sites More sharing options...
dv52 Posted October 2, 2017 Report Share Posted October 2, 2017 11 hours ago, smk82 said: Could someone with VCDS take a look to see if there are any settings changable on the average fuel consumption as its annoying me at how long it takes to register things (i.e cruise at 50 for 25 mins and it barely shifts the average consumption at all), when compared to my wife's A1 which adjusts fairly fast..? smk82: I've never tried changing this function, but if you go to the Instrument module @ address hex17 and then navigate to Byte 7, you should find the following options. As I said, I've not selected any of the other options, so a bit of experimentation needed! Don Quote Link to comment Share on other sites More sharing options...
smk82 Posted October 4, 2017 Author Report Share Posted October 4, 2017 these aren't the ones for adjusting the offset for the fuel calculation when the figures are off from calculating brim/brim? Quote Link to comment Share on other sites More sharing options...
dv52 Posted October 6, 2017 Report Share Posted October 6, 2017 On 10/4/2017 at 20:18, smk82 said: these aren't the ones for adjusting the offset for the fuel calculation when the figures are off from calculating brim/brim? smk82: no, that's an entirely different tweak as follows: Instrument control module @ address hex17> Enter security code: 20103> Change "IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration">adjust value (factory setting: 12.8; range: -8.0 to 8.0) Negative values decrease the fuel gauge, positive it raises. Calculation as remaining range are also affected. Don 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
Paperman Posted December 22, 2017 Report Share Posted December 22, 2017 Can any kind soul tell me where do I key in the security code:20103 to access the tank calibration page ? This is my first time using VCDS Quote Link to comment Share on other sites More sharing options...
8YARWY Posted December 22, 2017 Report Share Posted December 22, 2017 Can any kind soul tell me where do I key in the security code:20103 to access the tank calibration page ? This is my first time using VCDS Quote Link to comment Share on other sites More sharing options...
Paperman Posted December 23, 2017 Report Share Posted December 23, 2017 11 hours ago, veneeringman said: I tried clicking then type 20103. But faced: " invalid code". Is there anything wrong ? Quote Link to comment Share on other sites More sharing options...
dv52 Posted December 23, 2017 Report Share Posted December 23, 2017 hmm......... I reckon that you might have a late MY16/MY17 model Golf. If that's so, then the venerable 20103 doesn't work. The only security code that I'm aware-of for later model instrument modules is 25327, but this code only allows access to a very limited range of adaptation channels. Don PS: and your screenshot looks like it's from a very early version of VCDS. Assuming that you have a genuine cable, I suggest that you update the software Quote Link to comment Share on other sites More sharing options...
Paperman Posted December 23, 2017 Report Share Posted December 23, 2017 14 minutes ago, dv52 said: hmm......... I reckon that you might have a late MY16/MY17 model Golf. If that's so, then the venerable 20103 doesn't work. The only security code that I'm aware-of for later model instrument modules is 25327, but this code only allows access to a very limited range of adaptation channels. Don PS: and your screenshot looks like it's from a very early version of VCDS. Assuming that you have a genuine cable, I suggest that you update the software Yes. Im on jetta mk6 2015. Any codes i can try ? Thanks in advance !! Quote Link to comment Share on other sites More sharing options...
dv52 Posted December 23, 2017 Report Share Posted December 23, 2017 15 hours ago, Paperman said: Yes. Im on jetta mk6 2015. Any codes i can try ? Thanks in advance !! Jetta mk6? Isn't this vehicle built on a PQ35 platform? Why would a security code from a MQB platform vehicle work on a PQ35 platform vehicle? What am I missing from your question? Don Quote Link to comment Share on other sites More sharing options...
Paperman Posted December 24, 2017 Report Share Posted December 24, 2017 4 hours ago, dv52 said: Jetta mk6? Isn't this vehicle built on a PQ35 platform? Why would a security code from a MQB platform vehicle work on a PQ35 platform vehicle? What am I missing from your question? Don How can i access the fuel offset calibration setting for my PQ35 platform ? Thank you Quote Link to comment Share on other sites More sharing options...
Vidman Posted December 24, 2017 Report Share Posted December 24, 2017 Should you not post this Q in a Jetta forum not a Golf R forum where there will not be much interest. Quote Link to comment Share on other sites More sharing options...
