JamieKirk Posted March 25, 2018 Report Share Posted March 25, 2018 Hi all, Today I went to code the pace car indicators on my mk7r. I followed instructions on the forums, all going well. Pace car indicators working all fine when I pressed the hazard button. However when I went to test the indicators this was when I started having issues. When I indicated right only the outer o/s light was working When I indicated left both n/s lights and the inside o/s light started flashing So i reverted the settings to the normal hellphase lights, the hazards work fine but the indicators still have this problem. Please can anyone help with my dilemma, any help is always appreciated. Thank you Jamie Quote Link to comment Share on other sites More sharing options...
dazie00 Posted March 25, 2018 Report Share Posted March 25, 2018 Sounds like something is not done quite right , @dv52 is the VCDS guru on here , may ask to do a complete scan and reset a few mods and then start again , send Don a PM , hope you get it sorted asap . Quote Link to comment Share on other sites More sharing options...
JamieKirk Posted March 25, 2018 Author Report Share Posted March 25, 2018 Okay thank you, don't think i've got enough posts to PM but hopefully he can help on here, thank you Quote Link to comment Share on other sites More sharing options...
JamieKirk Posted March 25, 2018 Author Report Share Posted March 25, 2018 @negDid you have this problem? If so, how did you sort it please? Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted March 25, 2018 Report Share Posted March 25, 2018 Have a look here, Jamie. http://www.vwwatercooled.com.au/forums/f197/vcds-vag-com-codes-programmable-options-golf-mk7-84619-56.html#post1154325 Also, I took pace car indicators off my car and there’s info in this thread here: To get pace car indicators working, you need to change the Inner Indicator on each side from Dunkelphase to Hellphase. No other change necessary. Just make sure you get your Links (left) and your Rechts (right) sorted. It’s easy to change an Outer Indicator inadvertently which gives you the problem of three lights flashing. JamieKirk 1 Quote Link to comment Share on other sites More sharing options...
JamieKirk Posted March 27, 2018 Author Report Share Posted March 27, 2018 (edited) All sorted now, got them working, thank you for your help! Really appreciate it! Edited March 27, 2018 by JamieKirk LouCyffer 1 Quote Link to comment Share on other sites More sharing options...
