Lee63 Posted May 7, 2019 Report Share Posted May 7, 2019 Hi all, its been a while. I found a vcds how to sort of guide a while ago but cant find it now? Can anyone point me in the right direction please? Borrowed a friends but im a bit lost. Only trying to do the usual coding like exhaust flaps (mine are open but want to code back since res delete fitted) also turning off cornering lights etc.. any help is much appreciated. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
expor Posted May 7, 2019 Report Share Posted May 7, 2019 I cannot help you with the guide you're looking for. I just want to give you a heads-up on re-coding your exhaust flaps as this may not be as straight forward as you'd initially think. Simply putting the bit back to 'Exhaust flaps installed' does NOT enable flap control. Yes you still have to enable that bit of course, but it won't just work right after that. The only working solution I found was to disconnect the battery for at least 10 minutes and reconnect it. Only then the flaps were actually used again by the ECU when changing drive modes! Without it you'll find the flaps remain open in all modes at all times. Quote Link to comment Share on other sites More sharing options...
Lee63 Posted May 7, 2019 Author Report Share Posted May 7, 2019 Ah ok thanks for that expor i will see how it goes. Think i may just have to you tube how to do what ever bits im after doing Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted May 12, 2019 Report Share Posted May 12, 2019 Does this help, Lee? https://forums.vwvortex.com/showthread.php?7134970-VCDS-Tweaks-for-the-7R Lee63 1 Quote Link to comment Share on other sites More sharing options...
Lee63 Posted May 12, 2019 Author Report Share Posted May 12, 2019 Yes! Spot on thank you bud Sent from my iPhone using Tapatalk LouCyffer 1 Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted May 13, 2019 Report Share Posted May 13, 2019 I’m not far away if you need a hand Lee63 1 Quote Link to comment Share on other sites More sharing options...
Lee63 Posted May 13, 2019 Author Report Share Posted May 13, 2019 Thanks bud really appreciate that Think I’ve sorted it though. I had my exhaust valves coded open but recently had a resonator delete fitted the other week. It hums like a good one on a motorway run so wanted to code them back on to see if it helped soften the drone a bit. Cant really say i noticed much difference other than it been quieter when in eco overall but still drones at higher constant speed. Anyway I’ve coded them back open ha ha dropped the soundaktor to 80% too to take the edge off it which i quite like, its a little less intrusive and doesn’t vibrate the dash as much now. The only one i wanted to do but cannot find the right channels for was increase the day light running LED’s a little bit, not much just a bit more but its no biggie so I’m happy without messing with them to be fair. Waiting for OBD eleven to come onto IOS and then il pick that up. vcds is very good but it can be a bit confusing and long winded ay. I was going to buy a cheap tablet purely for obd eleven but now they are going to release an ios version i will wait. Sent from my iPhone using Tapatalk LouCyffer 1 Quote Link to comment Share on other sites More sharing options...
