Dynamic Light Assist
Kevmoz
Hi all,
I have a 7.5R with headlight assist so have the camera behind the mirror, but wondered if VCDS is able to make it dynamic? I’ve found this on the web https://www.ascoding.ch/en/activating-dynamic-light-assist-dla/
I don’t have VCDS and wondered if anyone had done it or could do it?
Cheers Kev
Do you have the camera on the windscreen or camera on the rear view mirror. I have high beam assist with camera on the rear view mirror. This one cannot be used for dynamic main beam assist. If you have the one on the windscreen it can. The only other question that I need answering is if there is a difference in the headlights that are used for DLA or is it the same as standard led headlights. If someone has the answer or part numbers for the headlights on a DLA car this will be useful to compare. I know from reading about DLA that the headlights have to be LED High version.
As indicated in your link -  DLA works by using a number of shutters that "hide" a portion of the high-beam illumination pattern from on-coming vehicles. The (correct) front facing camera and smarts in the control module track the route of on-coming vehicles so that the shutters change position and height with the path of approaching vehicles. Clearly for DLA to happen, the headlights must have the requisite shutters fitted.
DLA is  a sophisticated version of the plain, ordinary high-beam assist  function, which is a binary ON/OFF system where there is no vehicle tracking: the high-beams simply turn OFF when an on-coming vehicle is detected. Headlights for High-beam assist don't (normally) have variable multi-shutters. But perhaps check the part number on your headlights with a dealer
  • 4 weeks later...
On 18/01/2020 at 20:38, Kevmoz said:
Thanks for the reply’s. Mine has a camera on the mirror and not the screen, so it looks as if I’ll have to make do with high beam assist, which is no real hardship is it?
It depends on how much night driving you do on highways without any street lighting.
My R wagon has the fancy matrix headlights (ie with the variable shutters) and I find it useful to fully illuminate the roadside verges without dazzling other drivers in front of me.  Mind you, where I drive there are lots of kamikaze kangaroos and suicidal wombats, so it is helpful to see them before they leap out in front of you.  Around town it is no different to regular headlights.
  • 1 year later...
Hello,
What about adding DLA headlights to a vehicle that did not have that option?
I have a set of European DLA (5G1 941 043/044E) lights installed in a 2017 pre-facelift Golf R in Canada (NAR) and most of the functions are ok, no faults, but no high beam or flash to pass function. Tried coding the #55 module and it accepts the coding but then you lose the coding for the slave headlight modules in the process, still no high beams.
Looks like those modules have the part # 3D0 941 329 D that matches what the DLA lights have, maybe they are coded once by the factory? Tried coding them manually from '2E 00 00' to the DLA coding of '90 00 00' and they do not accept the coding.
If anyone out there knows how to resolve this, please let me know! I'm using ODIS so maybe its possible with VCDS or OBD11?
Thanks 🍻
