98 RON Minimum
Blackpug
  • 4 weeks later...
Unlikely due to the high excitement experienced by those guys who have been to see their new cars but...
Did anyone open the filler cap to see what fuel was written inside it?
On the mk6 R it was 98 big and bold. And 95 was in brackets very small. R soul on here rang up to clarify this with vw, and his answer was 98ron is recommended but you can run it on 95ron but the engine performance won't be optimal
So do you have total confidence that the supplying dealer will put 97/98 RON in the car when you pick it up?
I think the MK7 GTI's say 95 now , I still use 99 Fuel ,but not sure on the R ,However there will be plenty of theories
if it is 95 on the R , like what's it set for ,does it auto adjust ,Leaner burn ect ect ..... .
My dealer specifically told me ,before I mentioned it ,Full Tank of High Oct put in after PDI's drizzle :grin: By sales Dept ,
worked ok last time ,so Yea I trust them ... :smiley::smiley:
  • 2 weeks later...
Sorry to be a bit of a noob, but I will be using Tesco for fuel as its nearest (and for Clubcard points :embarrassed: ).
As it clearly states it is 98RON or more, surely this is ok to use?
Been using Tesco (and I think it's 99oct ) for Years , nearest shell station miles away !!!! they do say use 95 if stuck ,
but not more than half, half if possible because of all the Gizmos adjusting engine mix /burn ect... :wink:
If I had a shell station at the bottom of the road ,would probably use that to be politically correct with the OCT :nerd::nerd:
on the Forum .. :afro:
