Jmoore88 Posted June 25, 2022 Report Share Posted June 25, 2022 Just got a golf R yesterday and when I put my foot down the traction light flashes and kills the power but this is in the dry so can't be spinning, could this possibly be haldex failure? Just cleaned aload of crap out the filter but still the same. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted June 25, 2022 Report Share Posted June 25, 2022 It may hopefully just need priming which can be done with an obd11 device or similar. Happened to me a while back, thought the worst but primed it and engaged clutches and all worked again. Maybe it shuts down if not enough oil getting in, but doesn't throw an error or anything. Best to try before thinking about new pump and big £££. Do you actually get any wheelspin from the front, if launching you should get loads if the Haldex is not working. Quote Link to comment Share on other sites More sharing options...
Jmoore88 Posted June 25, 2022 Author Report Share Posted June 25, 2022 34 minutes ago, SpursMadDave said: It may hopefully just need priming which can be done with an obd11 device or similar. Happened to me a while back, thought the worst but primed it and engaged clutches and all worked again. Maybe it shuts down if not enough oil getting in, but doesn't throw an error or anything. Best to try before thinking about new pump and big £££. Do you actually get any wheelspin from the front, if launching you should get loads if the Haldex is not working. It's covered under warranty but to save me driving miles back to the garage I said I'd repair it my self if he funded the money but having another read it says it needs recoded to the car so it's going to be a garage job anyway. It's only drivable with traction control off but spins straight away Quote Link to comment Share on other sites More sharing options...
Deano Posted June 25, 2022 Report Share Posted June 25, 2022 17 minutes ago, Jmoore88 said: It's covered under warranty but to save me driving miles back to the garage I said I'd repair it my self if he funded the money but having another read it says it needs recoded to the car so it's going to be a garage job anyway. It's only drivable with traction control off but spins straight away A new haldex pump doesn’t need coded to the car. It just needs primed/re-learned via a scan tool such as VCDS or OBD11. As Dave says, worth replacing oil, cleaning filter and priming/re-learning first as that can sort a lot of issues. New haldex pump is circa £200, so not the end of the world if it has failed. If you have warranty send it straight back to garage. Is it a VW dealer you got it from? SpursMadDave 1 Quote Link to comment Share on other sites More sharing options...
Jmoore88 Posted June 25, 2022 Author Report Share Posted June 25, 2022 14 minutes ago, Deano said: A new haldex pump doesn’t need coded to the car. It just needs primed/re-learned via a scan tool such as VCDS or OBD11. As Dave says, worth replacing oil, cleaning filter and priming/re-learning first as that can sort a lot of issues. New haldex pump is circa £200, so not the end of the world if it has failed. If you have warranty send it straight back to garage. Is it a VW dealer you got it from? Not a vw garage but a reputable one, the guys says hel pay any costs to have it repaired. I'd posted this before he rang and said he'd cover the costs, iv had the pump out and it was black inside so chances are it's ran dry and seized anyway so new pumps on the cards Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted June 25, 2022 Report Share Posted June 25, 2022 If they are paying then might as well get a new pump for piece of mind 👍 Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted June 26, 2022 Report Share Posted June 26, 2022 It might also be worth checking that the gear in the transfer case (bevel box) isn't slipping on its shaft, this will turn your AWD R into a FWD wheel spinner. Most common on cars that have done lots of launches, especially tuned ones. There are a few YT videos around describing how to check (it isn't that easy to diagnose, and some people get it wrong) Quote Link to comment Share on other sites More sharing options...
Jmoore88 Posted June 26, 2022 Author Report Share Posted June 26, 2022 7 hours ago, gregozedobe said: It might also be worth checking that the gear in the transfer case (bevel box) isn't slipping on its shaft, this will turn your AWD R into a FWD wheel spinner. Most common on cars that have done lots of launches, especially tuned ones. There are a few YT videos around describing how to check (it isn't that easy to diagnose, and some people get it wrong) Will have a look now thanks Quote Link to comment Share on other sites More sharing options...
Jmoore88 Posted June 26, 2022 Author Report Share Posted June 26, 2022 11 hours ago, gregozedobe said: It might also be worth checking that the gear in the transfer case (bevel box) isn't slipping on its shaft, this will turn your AWD R into a FWD wheel spinner. Most common on cars that have done lots of launches, especially tuned ones. There are a few YT videos around describing how to check (it isn't that easy to diagnose, and some people get it wrong) Had a look at the videos theys no loud noises or banging from my car so hopefully not the bevel box shaft Quote Link to comment Share on other sites More sharing options...
Jmoore88 Posted June 26, 2022 Author Report Share Posted June 26, 2022 Had it plugged in to VCDS and its said mechanical heldex pump failure, also has intake manifold bankn1 stuck open🙃 good start to the Golf season gregozedobe 1 Quote Link to comment Share on other sites More sharing options...
