Touch Climatronic retrofit (Coding guide)
WHY.A.H.WHY.A
So, I had a touch control installed on my MK7 a few weeks ago.
I'm posting here my findings; it might help anyone interested in doing the swap.
Granted, the easiest way to avoid fault codes is to copy the long coding from the old module and use it on the new touch control, which I was not aware of at the time.
So, after the install, I got a few error codes:
XXXXXX - Adapt flap end stops - no basic setting.
B109EF0 - A/C compressor first run not performed
B108E54 - Rear temperature flap positioning motor - no basic setting
First, I started by clearing "Adapt flap end stops" by pressing the A/C and MENU buttons for a few seconds; this will cycle the flaps.
Then I noticed that the compressor won't kick in when pressing the AC button, and when I tried to run the basic settings in OBD11, it always gave a sequence error.
I found the answer online. By pressing A/C + rear defroster for around 30 seconds, it worked like a charm.
Playing around with the touch control, I noticed that the MENU button is not working this time.
AliExpress provided the answer:
I needed to change the following to make it work.
Channel 5F adaptation Car_function_list_BAP_GEN2
Change the following to active:
Climatic_master 0x01
Climatic_Slave 0x02
Aux_heating 0x03
I'm really not sure what these are, but the MENU button worked afterwards. The only downside is that I got a fault code:
U111100 - Function Limitation due to Missing Message
I can't clear this unless I revert the coding done to make the menu button work.
Anyone who is missing the "AirCare" option after the installation of the touch control, just go to long coding and change Filtering of interior compartment air & Air Quality sensor to Installed". this will also activate the AirCare button on the touch control.
After all is said and done, there is only one fault code I have: "Rear temperature flap positioning motor - no basic settings" I couldn't find any related entry in the long coding, so I'll keep investigating this; I'll update this space once I find a solution.
  • 8 months later...
still waiting ur investigation and I'm sure u will do it, keep going bro
On 22/12/2023 at 09:35, WHY.A.H.WHY.A said:
.....................there is only one fault code I have: "Rear temperature flap positioning motor - no basic settings" I couldn't find any related entry in the long coding.................................................
hmm............. maybe I'm missing something (very likely, I am) but I'm confused!!
I assume by the words "I had a touch control installed on my MK7", you mean the Climatronic controls below:
If so, the Climatronic system has a main temperature flap control motor V68 , a left temperature temperature flap motor V158 and a right temperature flap motor V159
AFAIK, there ain't a Rear temperature flap positioning motor on this module because there is no separate control for the rear of the car. So, I suspect that you won't find a software switch on this module for a Rear temperature flap positioning motor.
My hunch (guess really) is that the reason for your remaining error message is because the new module believes that it is installed in a different car to a mk7 - being a vehicle that has a control knob for heating/cooling to the car rear.
As you might be aware, the first few Bytes in the long-code tells the module what model car it is installed-in. Maybe post-up a copy of long-code string on the new 08 module so we can see how it's currently coded. And also tell us what car-side the steering wheel is located (country?) because this is an important piece of information for the leading Bytes!
Don .
Hey Don,
Thanks for your feedback, it's an old post, I updated it a few times over OBDeleven forums but forgot to do it here :).
Yes, my OP was referring to the Touch control referred in @golf7.5r picture.
Still getting "Rear temperature flap positioning motor - no basic settings" concluded that the module I have has the rear temp and flap hard coded. As per few posts on OBDeleven.
11 hours ago, dv52 said:
@WHY.A.H.WHY.A: OK thanks.
According to the long-code string that you posted on the OBD11 forum, the 08 module is correctly coded if this VW has:
  • left hand drive
  • Diesel engine
  • Auxiliary Heater (1 KW)
  • Front camera heating
Weird, are you sure it's my long coding? I basicly copied it from the old module,
Mine is Petrol, with no AUX heater, and no heated f. Cam
00020014100100011005004012101422
I'm not sure either (can't find where I got my previous values) - but this is your current long-code string in a more readable form:
Byte Hex Binary
00 00 00000000
01 02 00000010
02 00 00000000
03 14 00010100
04 10 00010000
05 01 00000001
06 00 00000000
07 01 00000001
08 10 00010000
09 05 00000101
10 00 00000000
11 40 01000000
12 12 00010010
13 10 00010000
14 14 00010100
15 22 00100010
Remember - Binary numbers are read from right-to-left. This means that the right-most digit is Bit 0 and the left-most digit is Bit 7
So, yes - petrol engine and left-hand drive (what country is this - clearly not UK?) And also yes, no AUX heater and no heated front camera. My bad - I guess!!
I don't have any information about your Byte 15 values - maybe check with whatever diagnostic device you use for the descriptors for Bit 1 and Bit 5
