jcull09 Posted June 2, 2025 Report Share Posted June 2, 2025 Hi VW R owners, I’m writing from Canada. I was notified by another driver that my rear blinkers (hazard warning lights) were flashing while I was stopped in traffic, waiting to turn left. I pulled over and found the following: Brakes applied + left turn signal = both rear turn signals flashing Brakes applied + right turn signal = no rear turn signal flashing No brakes applied + left turn signal = left rear turn signal flashing No brakes applied + right turn signal = right rear turn signal flashing The results are the same if the tail lights are illuminated or not. The issue has no impact on the front turn signals or the mirror turn signals, it only affects the tail light signals. This leads me to believe that there is an error in the coding and the application of the brakes is messing up the turn signals. Right now it’s a safety issue for me as I have had a few cars nearly run into my rear end not knowing that I’m attempting to turn (right), or they wait behind me confused as to why I’m in the middle of the road with my blinkers on / assuming I’m broke down. I have used an OBD code reader to see if there are any codes but nothing is showing. Therefore, I have ordered OBDeleven Pro and it will arrive in a couple of days. While I’m waiting, I would appreciate it if another North American Mk7.5 R owner could share their coding for their stock tail lights so I can compare and hopefully repair mine. You may be wondering how is this possible - the previous owner installed OEM European dynamic turn signals but he removed them / reverted back to stock prior to selling the car to me one year ago. He performed the coding updates himself but I’m guessing he messed something minor up. I’m also guessing the tail lights have malfunctioned for a whole year when the brakes are applied. I have searched various forums including this one for the past 48 hours and these are the conclusions I have come to. Thank you in advance for your help! Jamie Quote Link to comment Share on other sites More sharing options...
AHG Posted June 2, 2025 Report Share Posted June 2, 2025 Could also be a harness thing Shen you switch to Euro tail lights you need a harness that crosses the signals, so they may have left them there. You may want tot all to whoever sold the, the lights (ACM, DAP, BMP ?) they usually are quite knowledgeable as they see those issues daily Quote Link to comment Share on other sites More sharing options...
jcull09 Posted June 2, 2025 Author Report Share Posted June 2, 2025 Thank you for the response, AHG. I would agree, but in this case the previous owner returned everything back to stock because he was selling the euro tails as a package (tail lights, harness etc) separately. I will take a look at the harness for damage but I definitely want to compare coding between mine and a similar stock car (MK7.5 North American spec). Thanks again! Quote Link to comment Share on other sites More sharing options...
AHG Posted June 4, 2025 Report Share Posted June 4, 2025 Maybe try the Facebook group not many NAR people here Quote Link to comment Share on other sites More sharing options...
dv52 Posted June 5, 2025 Report Share Posted June 5, 2025 Jamie: Hi. If you are not aware, this is a model car that is built for the land of the God King (formerly the land of the free)!! Now, because I assume that you are a proud Canadian and NOT a devotee of the 51st State proposal - I assume that your view of the current POTUS is similar to mine. So, whilst I would immensely enjoy turning this reply into a very long discourse about the double (single?) digit IQ of said God King- I will avoid the fearsome wrath of the scary Moderators on this forum and stick to your tail-light problem,. However, I want you to know how difficult it is for me to abandon my preferred discussion topic - which should tell you something about them scary Moderators!!🤪 So, like most things that happen on the land of the God King, the tail lights on North America Region (NAR) models work differently to those on the rest of the world. Most particularly for this problem, the US Dept-of-Transport mandate that the same (red) light is used for both Brake and turn-signal (at least where incandescent tail-lights are fitted). So, my first question is - what flavor lights are NOW fitted to this car and do you know what type of lamps were factory fitted to this car? The latter question is important because it determines the wire-count in the factory loom that plugs into the tail-light fittings. OK - let's now get into the interesting stuff! Each of the 35 x exterior lights on this Golf is driven by what I call a "Leuchte-set". This is a group of 19 x adaptation channels that start with the word "Leuchte" ("Light" in English) in the channel name. So, the central module that manages the tail-lights has a total of 19 x 35 = 665 Leuchte-channels - which is quite impressive IMO!. As I said, each lamp in the tail-lights has it's own Leuchte-set and within that Leuchte-set, it is possible to code that lamp to preform up to 8 x lighting functions. Clearly for the outer tail-light fittings, a NAR model car needs to be coded as a Brake-light AND separately as a turn-signal lamp for the particular car-side. For the latter lighting function, there are 2 x separate Leuchte-commands for the left (licht) and right (recht) turn-signal sides. Based purely on your words: "Brakes applied + left turn signal = both rear turn signals flashing Brakes applied + right turn signal = no rear turn signal flashing" it is fairly clear that whoever coded this car has used the left (licht) side Leuchte-command on BOTH left and right side Leuchte-sets. The more interesting part of this problem is your words : "No brakes applied + left turn signal = left rear turn signal flashing No brakes applied + right turn signal = right rear turn signal flashing" Given the wrong coding when the Brake pedal is pressed - these observations suggest an even more "innovative" coding arrangement for the left/right side Leuchte-sets. I suspect the nature of this added coding error will ONLY be revealed when you fire-up the OBD11 software. Hopefully, my diatribe above makes rough sense - it's meant as an introductory response to steer you in the right direction. My fellow colleagues and I can add more stuff if you require further assistance as a new-bee OBD11 user! Happy coding and don't forget to make a few mistakes - they are absolutely the best learning events! Don Quote Link to comment Share on other sites More sharing options...
jcull09 Posted June 23, 2025 Author Report Share Posted June 23, 2025 Hi Don, Thank you for your helpful response! I am not a Canadian citizen, I am Irish and permanently residing in Canada, however, the God King continues to irritate me regardless of my nationality 🙃 Regarding the tail lights, the installed items are OEM North American parts. The previous owner had replaced them with OEM European parts but he reverted back to stock prior to selling the car. I finally got back to this and performed some further research last night and found Leuchte sets 20BR and 21BR (left and right outer tails) were the areas I needed to be focusing on. My reviews of each set quickly unearthed the problem: 20BR LA71 was good, 21BR RC8 was not good. As you rightly said, Don, the previous owner got his links and rechts confused. The devil was in the detail, Lichtfunction C21 was coded as follows: “Blinken links Dunkelphase” A simplie change to: ”Blinken rechts Dunkelphase” returned the God Kings DOT rear tail lights to full compliance / functionality. Thanks again, Don! Onwards and upwards. Jamie dv52 1 Quote Link to comment Share on other sites More sharing options...
