Al W Posted June 29, 2025 Report Share Posted June 29, 2025 I am a very recent owner of a 2022 VW T-ROC 2LITRE Diesel. Living a little north of Chichester, my daily drive is along twisty local roads with assorted potholes so there are constant lane warning alerts. I bought a OBDeleven to reprogram the LANE ASSIST to either OFF or MEMORY, but the one click app does not support this car. Has anyone achieved this change on a T-ROC with bit/byte direct updates ? If so, can you please give me a few words of help and guidance ? Thanks, Al Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 30, 2025 Report Share Posted June 30, 2025 7 hours ago, Al W said: I am a very recent owner of a 2022 VW T-ROC 2LITRE Diesel. Living a little north of Chichester, my daily drive is along twisty local roads with assorted potholes so there are constant lane warning alerts. I bought a OBDeleven to reprogram the LANE ASSIST to either OFF or MEMORY, but the one click app does not support this car. Has anyone achieved this change on a T-ROC with bit/byte direct updates ? If so, can you please give me a few words of help and guidance ? Thanks, Al Hi Al, welcome along. Might be worth you having a look at this thread (link below) and see if you can do it on a T Roc. This was done on a 2021 Golf R. https://www.vwroc.com/forums/topic/40084-golf-mk8-r-lane-assist-to-remember-last-setting-coding/page/3/#comment-618877 Quote Link to comment Share on other sites More sharing options...
Al W Posted August 8, 2025 Author Report Share Posted August 8, 2025 Still moving along.... T-ROC Registered2022 I used long word programming to turn off Lane Assist but got error code 31 when trying to save. What does this mean and how do I get round it ? Quote Link to comment Share on other sites More sharing options...
dv52 Posted August 8, 2025 Report Share Posted August 8, 2025 @Al W: Hi (again). As I suggested to my reply to your post on the OBD11 forum regarding this same matter - more detailed information is needed to understand this problem. Precisely what code change was attempted using "long word programming"? As for the specific OBD11 environment: Did you opt for a PRO license with your OBD11 purchase? Did you enable the SFD facility against your OBD11 account? Did you have ignition-ON, engine-OFF before starting the OBD11 diagnostic session and were the 2 x hood latches open ? As for your specific question "Has anyone achieved this change on a T-ROC with bit/byte direct updates?" - I suspect that the answer is NO. As you will read from Rebecca's (@Booth11) link, the tweak that @AHG describes is NOT a "bit/byte update" - it's a change to an adaptation channel in the A5 Module (front facing camera). Maybe you meant "adaptation programming" instead of "long word programming"? I don't know, I'm totally guessing- but a detailed explanation of the tweak that resulted in the "error code 31" will be greatly illuminating!! Don PS: Regarding @AHG observation: "The first two options render the stalk button useless and keeps it ON or OFF and the third option (which I thought would work) seems to get the same result as the fourth (how it was)" I suspect the 4 x options shown in the screenshot above mean: Off/On = the default status of Lane Assist at ignition-ON with NO ability to subsequently change Off/On (setting via menu) = the default status of Lane Assist at ignition-ON but status can be subsequently changed via MENU screen. On my MQB platform Audi A3, the fourth option is set and the behavior of Lane Assist is as I describe above.- meaning that unless I have activated Lane Assist via the MENU on a previous, or the current ignition-cycle - the Lane Assist button on the steering wheel stalk won't work and Lane Assist is default OFF. Quote Link to comment Share on other sites More sharing options...
