askmetwice Posted August 5, 2020 Report Share Posted August 5, 2020 Hi all, Newbie here with the same problem (I think), and a solution that made sense and helped my problem go away: I suddenly had several error messages popping up as well, they were: - Electronic stabilisation control (ECS) faulty - ParkPilot unavailable - Adaptive Front Lighting (AFL) not working - this after driving the car for a few seconds - Tire pressure monitoring unavailable - and maybe one or two more, I don't remember everything perfectly I had had a very similar problem two months ago, when my battery had given up the ghost as a result of it having been connected to the (Always active) cameras mounted to the windshield and back window. At that time, after I had changed the battery and factory reset the system, the messages had gone away. Last week, they suddenly popped up again. I took the car to the tyre place that had replaced my battery to have the battery checked. The battery was ship-shape (100 and 98%), so we ruled this out as the cause. However, the owner suggested that one of the wheel sensors could be at fault and referred me to another local garage nearby. They checked and - lo and behold - indeed one of the four sensors by the wheels was found to be faulty. As it measures a host of functions based on the rotations of the wheels, the faulty sensor had caused a range of functions to become unavailable. 1.5 hours and SGD235 (£130) later, the new sensor had been installed and the problems were gone, with all systems running properly again. Hope this may be of help to some. Hi all, Newbie here with the same problem (I think), and a solution that made sense and helped my problem go away: I suddenly had several error messages popping up as well, they were: - Electronic stabilisation control (ECS) faulty - ParkPilot unavailable - Adaptive Front Lighting (AFL) not working - this after driving the car for a few seconds - Tire pressure monitoring unavailable - and maybe one or two more, I don't remember everything perfectly I had had a very similar problem two months ago, when my battery had given up the ghost as a result of it having been connected to the (Always active) cameras mounted to the windshield and back window. At that time, after I had changed the battery and factory reset the system, the messages had gone away. Last week, they suddenly popped up again. I took the car to the tyre place that had replaced my battery to have the battery checked. The battery was ship-shape (100 and 98%), so we ruled this out as the cause. However, the owner suggested that one of the wheel sensors could be at fault and referred me to another local garage nearby. They checked and - lo and behold - indeed one of the four sensors by the wheels was found to be faulty. As it measures a host of functions based on the rotations of the wheels, the faulty sensor had caused a range of functions to become unavailable. 1.5 hours and SGD235 (£130) later, the new sensor had been installed and the problems were gone, with all systems running properly again. Hope this may be of help to some. Bob and gregozedobe 2 Quote Link to comment Share on other sites More sharing options...
Bob Posted August 17, 2020 Report Share Posted August 17, 2020 @askmetwice Very helpful and reassuring. Week or so ago had same thing happen to me during a long journey back home. Think other faults were auto hold, cornering lights and abs. Rear camera also stopped working. Pulled over and tyres fine. Carried on home as not giving me the stop driving warning. Next day was just esc and tyre warnings, which disappeared soon after started to drive. Not reappeared yet. Gave details via messenger to my local vag specialist who I have always used and they said almost certainly a rear abs sensor (ie wheel sensor). They have been changing a few recently! About 150 quid to change but no repeat yet so will wait until/if it happens again. Which in time I'm sure it will. Cheers Bob gregozedobe 1 Quote Link to comment Share on other sites More sharing options...
Fire_2 Posted March 2, 2022 Report Share Posted March 2, 2022 new rear left genuine abs sensor sorted out all my issues thanks guys (£92 from stealers) gregozedobe 1 Quote Link to comment Share on other sites More sharing options...
WesleyGO Posted July 27, 2022 Report Share Posted July 27, 2022 When coming back from Italy last week I had also a lot of errors coming up. I was driving that day already (without any rain) for 8 hours. Suddenly on the highway the circus started; furious messages popped up and I even with the gear in "D" the gear unclutched. I tried to start it, but all messages came back. After waiting a bit longer I was lucky it started again and able to drive home. Last week the car started sometimes (just to check), but also sometimes all messages appeared again. (I exchanged the battery already with a friends car and deleted all messages by VCDS, but that is not the solution) Now reading on this forum I also think it might be the ABS-Sensor: I had a small accident/crash a bit more than a week before at my right front wheel. But at that moment the damage looked only physical (Maybe its's more?). Errors I currently have: 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 14-Susp. Elect. -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: Malfunction 0010 (This error was there already) 19-CAN Gateway -- Status: Malfunction 0010 2B-Steer. Col. Lock -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 69-Trailer -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010 It is quite some errors (also Airbags?!), but I really hope you are all right! I have ordered a complete new bearing including ABS sensor for my right front wheel. I keep you updated if it will solve the problem after replacing, hopefully to help more persons! Please let me know if someone recognizes the problem above as something else. Quote Link to comment Share on other sites More sharing options...
dazbcos1969 Posted June 12, 2023 Report Share Posted June 12, 2023 On 27/07/2022 at 01:53, WesleyGO said: When coming back from Italy last week I had also a lot of errors coming up. I was driving that day already (without any rain) for 8 hours. Suddenly on the highway the circus started; furious messages popped up and I even with the gear in "D" the gear unclutched. I tried to start it, but all messages came back. After waiting a bit longer I was lucky it started again and able to drive home. Last week the car started sometimes (just to check), but also sometimes all messages appeared again. (I exchanged the battery already with a friends car and deleted all messages by VCDS, but that is not the solution) Now reading on this forum I also think it might be the ABS-Sensor: I had a small accident/crash a bit more than a week before at my right front wheel. But at that moment the damage looked only physical (Maybe its's more?). Errors I currently have: 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 14-Susp. Elect. -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: Malfunction 0010 (This error was there already) 19-CAN Gateway -- Status: Malfunction 0010 2B-Steer. Col. Lock -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 69-Trailer -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010 It is quite some errors (also Airbags?!), but I really hope you are all right! I have ordered a complete new bearing including ABS sensor for my right front wheel. I keep you updated if it will solve the problem after replacing, hopefully to help more persons! Please let me know if someone recognizes the problem above as something else. Hi Did the wheel bearing fix your issues? Thanks Darren Quote Link to comment Share on other sites More sharing options...
