Help with codings please....
savage16v
Hi all,
I want to make some changes using VCDS (never used it before), with the help of a friend who uses the software regularly.
I am after some help in the codings for the things I am looking to do if anyone would be so kind?
Alarm chirp
Sound actuator volume
Rear brake lights - Have the code for this
DRL brightness - Have the code for this
Washer delay - Have the code for this
If anybody has any other interesting suggestions of neat things to do whilst plugged in, I am all ears :)
Thanks for any help in advance :)
Alarm Beep - two parts, you dont have to do either but it could be useful to have.
1, Enable on lock and/or unlock first ...
Central Electronics (09)
Secuity Access -  31347
Search the adaption channels for ...
(1)-Acknowledgement Signals -Akustische Rueckmeldung entriegen (UNLOCKING) set to ON/ENABLE
(2)-Acknowledgement Signals -Akustische Rueckmeldung verriegeln (LOCKING) set to ON/ENABLE
2, then to enable the menu on the media screen under 'locking' - this is just for enabling or disabling the options which you set above so an overall on/off not lock/unlock
(7)-Acknowledgement Signals -Menuesteuerung akustische Rueckmeldung set to ENABLE/ON
Rear brake lights look so much better, followed a GTI with LED's (same as the R) and it looked a little crap compared to the outer and inner lights being on.
Cheers for the code mate, yeah I followed the better half, she was in the Golf and I really dislike the brake lights just being the outer, don't like it at all.
Don't suppose you have the soundaktor volume do you? :)
1.  A9 (Structure Borne Sound).
2.  Choose Adaption 10.
3.  At Channel drop down choose "Volume of structure borne noise actuator" (this is the only choice).
4.  Enter a value in the box (0= off; 100 = full volume), personally i chose 75%.
5.  Close out with "Do it".
6.  It also asks for a code, but VCDS suggests one, just OK it.
Excellent, thanks mate :)
Got all the codes I need now!
Hopefully do it tonight :)
  • 4 weeks later...
Hi all,
Alarm chirp
Have you a file with all of these on, i have someone local to me that has a VCDS but needs to know what to do? or is there a PDF someone has created to list all the changes you can do how to etc>>>
