Pigpen Posted April 1, 2015 Report Share Posted April 1, 2015 Have been unwell prior and after collecting the R - probably all the excitement Anyways as the weather has been totally sh*te I have decided to leave the R tucked up in the garage and continued to use the pot hole crusher. But tonight when I parked up I noticed the alignment of the rear bumper with the adjacent panel was flush one side but recessed by 3-5mm on the other. Is this normal / acceptable within VW standards or should I make an issue about it? Is it easy to correct or likely to cause more damage being corrected so just ignore it? Appreciate any advice. VW7R and Tom 2000 2 Quote Link to comment Share on other sites More sharing options...
TechieAli Posted April 2, 2015 Report Share Posted April 2, 2015 Pics, its hard to tell without pictures so we can all look at ours and compare. Quote Link to comment Share on other sites More sharing options...
Harryr34 Posted April 2, 2015 Report Share Posted April 2, 2015 The gap between the tailgate and glass is approx 4mm bigger on the left side compared to the right on my car, VW don't seem to have any standards whatsoever... My supplying dealer fobbed me off saying they don't have a VW approved body shop, I've complained to VWCS whom recomended a couple of local dealers with body shops; these two dealers have some rubbish reviews online hence I haven't followed it up yet. Pigpen and VW7R 2 Quote Link to comment Share on other sites More sharing options...
VW7R Posted April 2, 2015 Report Share Posted April 2, 2015 Have been unwell prior and after collecting the R - probably all the excitement Anyways as the weather has been totally sh*te I have decided to leave the R tucked up in the garage and continued to use the pot hole crusher. But tonight when I parked up I noticed the alignment of the rear bumper with the adjacent panel was flush one side but recessed by 3-5mm on the other. Is this normal / acceptable within VW standards or should I make an issue about it? Is it easy to correct or likely to cause more damage being corrected so just ignore it? Appreciate any advice. Sorry to hear you have not been well. In fact, when I collected my R, I was also pretty unwell and found it really difficult to take in all the information during the handover which I must admit was superb. The car had been prepared immaculately and is as faultless as a mass production car can be. Regarding your rear bumper and rear quarter panel fit, they should be absolutely perfect and flush on both sides with no difference. Mine is perfectly aligned: I've just checked. A 3mm-5mm recess is a huge. So, you should take it back to the dealer to get this sorted. Pity you have this issue, especially after such a traumatic and long gestation delivery process for your little Miss Piggy. Tom 2000 and Pigpen 2 Quote Link to comment Share on other sites More sharing options...
Pigpen Posted April 2, 2015 Author Report Share Posted April 2, 2015 Sorry to hear you have not been well. In fact, when I collected my R, I was also pretty unwell and found it really difficult to take in all the information during the handover which I must admit was superb. The car had been prepared immaculately and is as faultless as a mass production car can be. Regarding your rear bumper and rear quarter panel fit, they should be absolutely perfect and flush on both sides with no difference. Mine is perfectly aligned: I've just checked. A 3mm-5mm recess is a huge. So, you should take it back to the dealer to get this sorted. Pity you have this issue, especially after such a traumatic and long gestation delivery process for your little Miss Piggy. Its not the recess that is 3-5mm wide that is the difference between the panels so instead of being flush one sticks proud of the other 3-5mm. My dealer said they would look at it but it's 100 mile round trip VW7R 1 Quote Link to comment Share on other sites More sharing options...
VW7R Posted April 2, 2015 Report Share Posted April 2, 2015 Its not the recess that is 3-5mm wide that is the difference between the panels so instead of being flush one sticks proud of the other 3-5mm. My dealer said they would look at it but it's 100 mile round trip I did understand exactly what you meant. There should not be this difference. They should be flush with each other and no difference either side.The bumper needs to be re-aligned or it could be warped. Hope it is not the latter as I had this with my Mk6 GTI. Because if one side is flush and the other is not, then you have a problem. PITA. I must admit when comparing overall fit and finish to the S3, the R is the poor relation, no doubt. Pigpen 1 Quote Link to comment Share on other sites More sharing options...
Pigpen Posted April 2, 2015 Author Report Share Posted April 2, 2015 Just worried they might do more damage! Quote Link to comment Share on other sites More sharing options...
VW7R Posted April 2, 2015 Report Share Posted April 2, 2015 Just worried they might do more damage! Why don't you go to a VW Approved Bodyshop or VW Dealer closer to your home. The Warranty work can be carried out by any VW Dealer or VW Approved Bodyshop. It is not a prerequisite that only the supplying dealer needs to complete Warranty work. Pigpen 1 Quote Link to comment Share on other sites More sharing options...
Pigpen Posted April 2, 2015 Author Report Share Posted April 2, 2015 This is the SW that is my nearest dealer To be fair there is one a little nearer but last time we dealt with them they parked a courtesy car in our flower bed! We had to get a tractor to pull it out and the repair bill was around £5k. Do you think I should call them? Might be worth investigating where their approved body shop is as it may be nearer. VW7R 1 Quote Link to comment Share on other sites More sharing options...
monkeyhanger Posted April 2, 2015 Report Share Posted April 2, 2015 Sorry to hear you have not been well. In fact, when I collected my R, I was also pretty unwell and found it really difficult to take in all the information during the handover which I must admit was superb. The car had been prepared immaculately and is as faultless as a mass production car can be. Regarding your rear bumper and rear quarter panel fit, they should be absolutely perfect and flush on both sides with no difference. Mine is perfectly aligned: I've just checked. A 3mm-5mm recess is a huge. So, you should take it back to the dealer to get this sorted. Pity you have this issue, especially after such a traumatic and long gestation delivery process for your little Miss Piggy. Definitely not acceptable, makes me think it has had a new bumper fitted (badly) following a minor transit bump, or it has taken on a soft bump that didn't leave a mark in the paint. My GTDs rear bumper was perfectly aligned new, and the replacement one following a rear shunt was fitted just as well - tiny gap between the bumper and the rear quarter panel, literally just wide enough to get a piece of thick paper/thin card between. Quote Link to comment Share on other sites More sharing options...
AgentFruit Posted April 2, 2015 Report Share Posted April 2, 2015 The panel fit on both my cars has been spot on - what you describe is definitely not right. Without a photo its hard to tell exactly where you're talking about on the car, but it sounds as though the bumper has been leaned on by another car in transit perhaps. If this is the case, have you tried gently pulling the bumper back? When I had my slight altercation with a pillar in a car park, the rear bumper moved forwards like you describe and sat about 3mm proud of the adjacent panel. When I pulled it back it slipped nicely back into its clip. Worth a go? Quote Link to comment Share on other sites More sharing options...
Pigpen Posted April 2, 2015 Author Report Share Posted April 2, 2015 I'll try and get some photos up. It doesn't stand out like a sore thumb but something made me check it out. Tom 2000 1 Quote Link to comment Share on other sites More sharing options...
VW7R Posted April 2, 2015 Report Share Posted April 2, 2015 This is the SW that is my nearest dealer To be fair there is one a little nearer but last time we dealt with them they parked a courtesy car in our flower bed! We had to get a tractor to pull it out and the repair bill was around £5k. Do you think I should call them? Might be worth investigating where their approved body shop is as it may be nearer. Try the nearest one out. If joy is missing from the visit, then enjoy driving to your supplying Dealer. Hope you get it sorted. Very annoying with these little niggles. Quote Link to comment Share on other sites More sharing options...
AgentFruit Posted April 2, 2015 Report Share Posted April 2, 2015 I'll try and get some photos up. It doesn't stand out like a sore thumb but something made me check it out. 1mm very max, but not 3-5mm. If you can't move it yourself, take it to your dealer. 100 miles round trip is nothing in a car you like driving. If you can't be bothered at least take it to a local one for an opinion - you don't have to use them. Quote Link to comment Share on other sites More sharing options...
VW7R Posted April 3, 2015 Report Share Posted April 3, 2015 On my car the passenger side front door is not quite perfectly aligned. It is a teeny weeny bit out but nothing that really bothers me too much. Saw two other Rs with the same slight misalignment of the front passenger door. Quote Link to comment Share on other sites More sharing options...
