Rampantdidact Posted January 27, 2016 Report Share Posted January 27, 2016 Not trying to be a smart arse or anything but are your headlights clean? After I wash the car I notice a big difference on my headlight range. Quote Link to comment Share on other sites More sharing options...
skip72 Posted January 27, 2016 Report Share Posted January 27, 2016 Looks like full LED headlights are on the way, in which case the functionally useless headlight washers when without wipers may disappear. They're currently obligatory with xenons, but I wonder if they are with LEDs. w the wife's mini has full LED headlights, there are no headlight washers so I assume the requirements are different. maybe due to lens design etc. Quote Link to comment Share on other sites More sharing options...
skip72 Posted October 3, 2016 Report Share Posted October 3, 2016 Old topic I know but I thought I'd share with you my experience. I have a 2014 r and I've always been disappointed with the headlights. The throw of the lights is so poor on dipped in comparison to my last car, an Audi TT. I've had the lights adjusted by my local VW dealer last winter but no real improvement was seen when on unlit roads. so having read a number of posts on this I took the plunge last week and swapped the headlight bulbs for Philips Xenon X-treme Vision DS3. I've found the light a lot more natural but still no better on distance. However that's when I noticed the "fogging" on the lenses. I took it to my VW dealer and compared the lights to the current Golf R, spotless. Cutting a long story short I'm having the headlights replaced today for a new set, under warranty, keeping the Philips Xenon X-treme Vision bulbs. I'll update this post once I've tested them out tonight Meercat and tobys 2 Quote Link to comment Share on other sites More sharing options...
g7nickh Posted October 3, 2016 Report Share Posted October 3, 2016 have you a boot full of stuff? having a heavy load in rear will adjust the lights down so not to dazzle? Dealers only do stuff by the manuals , but on the golf xenons there are left/right and height adjusters in the headlight units a hex socket I think or was it philps ? any way they can offer a small amount of adjustment .. if you want to go crazy then you can fit the load leveller device installed on the rear axle at a different angle to bring the lights up..needed a large washer. Did it when lowered my last golf. My new R's are great - seem a bit high but not complaining.. have also fitted the Philips D3s which were also in the last golf.. these are brighter and whiter than standard. fitting is a pain, but can be done without removing bumper.. although annoyingly did drop a tool and screw in the recess of bumper s.. which necessitated much swearing and more screws and grazed arms.. Quote Link to comment Share on other sites More sharing options...
skip72 Posted October 4, 2016 Report Share Posted October 4, 2016 So, new headlights fitted and what a difference. I can actually see ahead. I've also discovered that dynamic light bending actually works, It was like driving a new car last night watching the lights move with the steering wheel. I was like a child with a new toy lol interestingly VW released a service bulletin for this very issue, fogging of the headlight lenses, and the recommended action is to replace headlights. so its a known problem. there are still a few marks on the lens but nothing compared to previous, I'll let them bed in for a couple of weeks and provide a longer term update tobys 1 Quote Link to comment Share on other sites More sharing options...
oli2005 Posted February 2, 2017 Report Share Posted February 2, 2017 Thought I would just let others know that today I have had two front headlight units replaced under warranty due to the fogging issues as mentioned above, this caused my headlights to be less effective, since having them changed what a difference, crystal clear light! The dealer was saying VW are aware of this issue around the fogging up of the projector inside of the headlight unit and they have had a service memo issued about it. Albeit mine is 2014 R not sure if they have sorted this problem on newer models or not. I wouldn't of known about this until I read this topic either tobys and gigolo456 2 Quote Link to comment Share on other sites More sharing options...
Vidman Posted February 4, 2017 Report Share Posted February 4, 2017 have you a boot full of stuff? having a heavy load in rear will adjust the lights down so not to dazzle? Dealers only do stuff by the manuals , but on the golf xenons there are left/right and height adjusters in the headlight units a hex socket I think or was it philps ? any way they can offer a small amount of adjustment .. if you want to go crazy then you can fit the load leveller device installed on the rear axle at a different angle to bring the lights up..needed a large washer. Did it when lowered my last golf. My new R's are great - seem a bit high but not complaining.. have also fitted the Philips D3s which were also in the last golf.. these are brighter and whiter than standard. fitting is a pain, but can be done without removing bumper.. although annoyingly did drop a tool and screw in the recess of bumper s.. which necessitated much swearing and more screws and grazed arms.. Do you have any detailed fitting instructions for this mod. My lights are at the top of the available adjustment but they are still very low. Did not know there was a leveler device on the rear axle. Any info would be great. Quote Link to comment Share on other sites More sharing options...
