robdfr Posted January 6, 2016 Report Share Posted January 6, 2016 I know there has been some posts already commenting about how good or how bad the headlights are on the golf R. I was in the camp that thought my headlights were actually quite good compared to the xenons in my Leon Cupra. But since my car went in for its first service at the end of November , the performance of my headlights have been pants ! The crisp white light has gone and the lights are very yellowed in comparison , wet roads at night are dangerous with the amount of light that is now generated by the headlights. Also I have noticed that when the lights are on , if you look at the bulb housing on the headlight when its on it looks like the housing has smear marks around them deffo stopping the light coming out. Its got to the point where my turning lights are brighter than my xenons ! Has anyone else noticed their lights getting worse? Quote Link to comment Share on other sites More sharing options...
chris_blue Posted January 6, 2016 Report Share Posted January 6, 2016 Mine are very good in all honesty, and the OEMs on my last motor were awful- almost dangerous. However, am only 2 weeks into ownership, so will give it another couple months before my next comment Quote Link to comment Share on other sites More sharing options...
oryxgolfr Posted January 6, 2016 Report Share Posted January 6, 2016 Mine's 18 months old and they are fine. Check that they haven't inadvertently been adjusted for right lane driving...this is done in the "Menu". I used my car to drive to Switzerland and switched to right hand mode and all it does is lower the lights to stop dazzling oncoming traffic subsequently making them close to useless. Quote Link to comment Share on other sites More sharing options...
KennyGTI Posted January 6, 2016 Report Share Posted January 6, 2016 I just changed my bulbs to the Philips Xtreme Vision on Monday and noticed a difference in brightness. I recommend doing this to yours. I'm not sure if the 6R was any better than the 7R or all the threads on here made me think the light output was poor, but thought to change the bulbs anyways Quote Link to comment Share on other sites More sharing options...
simpleR Posted January 6, 2016 Report Share Posted January 6, 2016 Mine's 18 months old and they are fine. Check that they haven't inadvertently been adjusted for right lane driving...this is done in the "Menu". I used my car to drive to Switzerland and switched to right hand mode and all it does is lower the lights to stop dazzling oncoming traffic subsequently making them close to useless. If your lights are switched to left hand drive mode it will warn you everytime you turn the ignition on. After 21 months i dont think mine are great - i will compare to the replacement R when i collect in a few days. Quote Link to comment Share on other sites More sharing options...
TechieAli Posted January 6, 2016 Report Share Posted January 6, 2016 I just changed my bulbs to the Philips Xtreme Vision on Monday and noticed a difference in brightness. I recommend doing this to yours. I'm not sure if the 6R was any better than the 7R or all the threads on here made me think the light output was poor, but thought to change the bulbs anyways Which bulbs did you change? The H7's that you can access are the cornering lights? Quote Link to comment Share on other sites More sharing options...
ColC1981 Posted January 6, 2016 Report Share Posted January 6, 2016 Mine's 18 months old and they are fine. Check that they haven't inadvertently been adjusted for right lane driving...this is done in the "Menu". I used my car to drive to Switzerland and switched to right hand mode and all it does is lower the lights to stop dazzling oncoming traffic subsequently making them close to useless. Mine are set to this now as i'min Germany, I agree it does lower them,however it ever so slightly moves them to the right too, i have seen this on the light tester,this makes them legit for Europe. If your lights are switched to left hand drive mode it will warn you everytime you turn the ignition on. After 21 months i dont think mine are great - i will compare to the replacement R when i collect in a few days. Yep every time you start up it warns you Quote Link to comment Share on other sites More sharing options...
thanksabunch Posted January 6, 2016 Report Share Posted January 6, 2016 My R is a week old and headlights seem spot on although there's condensation in them which im not too happy about! Might book it into dealers to take a look at them! chris_blue 1 Quote Link to comment Share on other sites More sharing options...
neg Posted January 6, 2016 Report Share Posted January 6, 2016 Give it time for the condensation to sort itself out - I had this in the front indicators, soon went and its not returned. To be honest the dealer will only tell you the same to begin with. Quote Link to comment Share on other sites More sharing options...
KennyGTI Posted January 6, 2016 Report Share Posted January 6, 2016 I changed the dipped beam bulbs D3S Quote Link to comment Share on other sites More sharing options...
thanksabunch Posted January 6, 2016 Report Share Posted January 6, 2016 Give it time for the condensation to sort itself out - I had this in the front indicators, soon went and its not returned. To be honest the dealer will only tell you the same to begin with. Yes that's where it is on mine actually Mild condensation in lower of both lights! Bit annoying considering the car is new but as you say I'll give it a few weeks then book it into stealers if no better :-( Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 6, 2016 Report Share Posted January 6, 2016 Mine's 3 months old and lights are fine, as bright as day one, so far. Condensation tends to be quite a common problem with bi-xenons and usually does settle down. That said I've not had any issues with it myself so far. OP - as said, check your settings, especially as the lights only seem to have altered since they went in for service. It's surprising what dealers will mess around with when they have the car, and of course testing the lights is on the maintenance checklist. Good luck and hope you get it sorted. Quote Link to comment Share on other sites More sharing options...
chris_blue Posted January 6, 2016 Report Share Posted January 6, 2016 Yes that's where it is on mine actually gonna try dessicant pack Mild condensation in lower of both lights! Bit annoying considering the car is new but as you say I'll give it a few weeks then book it into stealers if no better :-( Same as mine- gonna try dessicant pack Back window gets condensation too- tried spraying some stuff on inside, see how that goes Quote Link to comment Share on other sites More sharing options...
DaveGrohl Posted January 7, 2016 Report Share Posted January 7, 2016 Your lights don't sound good robdfr, quite alarming in fact. I'd have it straight back to the dealers, I've been critical of the standard lights but yours sound worrying. It either sounds like they've swapped the bulbs for some poorer ones for some strange reason, or there's a layer of crap that's got into the lenses whilst at the dealers. Either way I'd be demanding answers. Re the lights themselves, my view is that the lenses have been designed in such a way that they spread more light sideways to the side of the road/onto hedges at the expense of the straight ahead illumination. The lights are definitely not as good as on the 6R. There is the proviso mind that you do find yourself travelling maybe 10mph faster in the 7R at any given moment at night than in a 6R. Personally, I want to see where I'm going NOT where I don't want to end up! Anyhoo, best solution is to swap the bulbs for the Philips ones mentioned by Kenny earlier in the thread. They are a definite improvement. I am no longer scared driving at night. Hope you get sorted. tobys 1 Quote Link to comment Share on other sites More sharing options...
robdfr Posted January 9, 2016 Author Report Share Posted January 9, 2016 Thanks for all of the suggestions , Yesterday I went into the menu and changed the light setting to right hand drive , I did this with the lights on and against a van in front of me and I could see the lights move lower , so my settings were correct. I have also noticed my drls are a lot less bright than they used to be , is there a string to make them brighter ? Either on the car menu or using vcds? I might alter the position because they do see low to me , but I have no idea why the crisp white light has changed , later when it gets dark I will take a photo of the smearing on the light housing glass , you can only see it when they are on. Quote Link to comment Share on other sites More sharing options...
