Phone prep differences
Obbzi
Not sure if it is climate screen but certainly heated screen. The salesman told me that having the heated screen causes a loss in phone signal and therfore it is automatically coupled with the advance phone prep (as per the configurator). To be honest, having just come from a Skoda with heated windscreen and standard entertainment system phone worked absolutely fine in the car without any additional phone prep (which you could be specced if wanted). So is it really necessary? I very much doubt it.
The climate screen reduces the phone signal inside the car. The advanced phone connection puts an induction loop in the centre arm rest cubby box that will boost mobile phone reception by allowing your phone to utilise the cars external aerial, when the phone is mounted in the cubby box. You also get an additional USB connection in there too.
If you opt for the climate screen your forced to have the advanced phone connection too. If you live in a good area for phone reception you probably don't need it.
Follow the link in my signature, there's pictures of the standard and advanced phone connection.
I've got the climate comfort windscreen and can confirm it does interfere with signals on phones and also window mounted sat navs.  Advanced prep is a must if you have the climate option specced...having said that I can't recommend it enough...it absolutely sorts a frosted windscreen in about 2 mins flat...no messing with scrapers and cold hands in the morning
the "holster" is basically an elastic strap on the forward facing side of the arm rest storage area.  it holds the phone in place and secures it near the induction loop fitted to cars with climate comfort windscreens.  I didn't get a cable either...I'm using a spare one I had for connecting to the USB slot in the arm rest.
