Obbzi Posted March 31, 2016 Report Share Posted March 31, 2016 I think my car just has the standard Bluetooth but what is the difference between standard and advanced phone prep? And to change is it just a case of upgrading the Bluetooth module and some vcds coding? Quote Link to comment Share on other sites More sharing options...
Sammo Posted April 1, 2016 Report Share Posted April 1, 2016 Advanced phone prep is basically a port in armrest to cable in your phone to boost signal. Quote Link to comment Share on other sites More sharing options...
ColinC2 Posted April 1, 2016 Report Share Posted April 1, 2016 I thought that the boost was supplied by the little strips on the underside of the armrest ? Quote Link to comment Share on other sites More sharing options...
xPETEZx Posted April 1, 2016 Report Share Posted April 1, 2016 Does it only boost signal if the phone is placed in the cubby? I read you 'needed' it to compensate if you had climate Windscreen. Curious if anybody with the Climate screen can confirm it kills reception in the car? Quote Link to comment Share on other sites More sharing options...
JerryT Posted April 1, 2016 Report Share Posted April 1, 2016 Not sure if it is climate screen but certainly heated screen. The salesman told me that having the heated screen causes a loss in phone signal and therfore it is automatically coupled with the advance phone prep (as per the configurator). To be honest, having just come from a Skoda with heated windscreen and standard entertainment system phone worked absolutely fine in the car without any additional phone prep (which you could be specced if wanted). So is it really necessary? I very much doubt it. Quote Link to comment Share on other sites More sharing options...
bRum bRum Posted April 1, 2016 Report Share Posted April 1, 2016 The climate screen reduces the phone signal inside the car. The advanced phone connection puts an induction loop in the centre arm rest cubby box that will boost mobile phone reception by allowing your phone to utilise the cars external aerial, when the phone is mounted in the cubby box. You also get an additional USB connection in there too. If you opt for the climate screen your forced to have the advanced phone connection too. If you live in a good area for phone reception you probably don't need it. Follow the link in my signature, there's pictures of the standard and advanced phone connection. tobys 1 Quote Link to comment Share on other sites More sharing options...
TechieAli Posted April 2, 2016 Report Share Posted April 2, 2016 I thought there is also an induction loop under the front cubbie hole by the gear lever. Quote Link to comment Share on other sites More sharing options...
hendea00 Posted April 2, 2016 Report Share Posted April 2, 2016 I've got the climate comfort windscreen and can confirm it does interfere with signals on phones and also window mounted sat navs. Advanced prep is a must if you have the climate option specced...having said that I can't recommend it enough...it absolutely sorts a frosted windscreen in about 2 mins flat...no messing with scrapers and cold hands in the morning Quote Link to comment Share on other sites More sharing options...
Raymondmc9 Posted April 2, 2016 Report Share Posted April 2, 2016 I too have the comfort windscreen and was a great option to have during the cold months however not had any issues with signal from Orange iPhone and O2 Lumia...never even used advanced prep. I understand you need to removed the cover from the phone and strap it in position Quote Link to comment Share on other sites More sharing options...
hendea00 Posted April 2, 2016 Report Share Posted April 2, 2016 I leave my iPhone 6s Plus in its cover and slide it into the "holster" in the armrest and it seems to do the trick and boosts the signal. tobys 1 Quote Link to comment Share on other sites More sharing options...
Sammo Posted April 3, 2016 Report Share Posted April 3, 2016 I leave my iPhone 6s Plus in its cover and slide it into the "holster" in the armrest and it seems to do the trick and boosts the signal. I have advanced phone prep but what's the holster? They didn't even give me a cable! Quote Link to comment Share on other sites More sharing options...
hendea00 Posted April 3, 2016 Report Share Posted April 3, 2016 the "holster" is basically an elastic strap on the forward facing side of the arm rest storage area. it holds the phone in place and secures it near the induction loop fitted to cars with climate comfort windscreens. I didn't get a cable either...I'm using a spare one I had for connecting to the USB slot in the arm rest. tobys 1 Quote Link to comment Share on other sites More sharing options...
