VCDS not opening module?
ashleyman
Got my cable delivered today and installed the software on a windows laptop.
The first software I installed was 12.12.3a then I realised this was out of date when the cable wasn't picking up the car. I then updated to 14.10.0 and this time it picked up the car.
My first test I wanted to do to make sure everything was working was to disable the exhaust flaps but when I went into the engine module and then click on coding and go to BIT 9 I didn't have the same options as what was on the tutorial on YouTube.
Again, I restarted everything and got a newer update so I installed that so now I'm running 14.10.2. Still reads the car but it won't open the engine module when you click on it. I tried a few of the others like instrument etc... All do the same thing. They just do not open.
It spins the mouse, then stops and nothing happens. Is this likely to be a software thing or a cable issue?
Did you buy it from Gendan? Can they help? The US should be waking up now so maybe contact VCDS site?
I didn't get it from Gendan, no.
I only bought a cheap one so I could disable and re-enable my exhaust flaps so I can be 100% sure thats my squeaking problem before the car goes back to the dealer.
I know I can't expect much help as I bought a cheap cable but it was literally only to test the flaps. Everything else would have been a bonus if the cable was able to do anything else...
My cable was one from a seller online but can't remember where, it came with a link of where to download VCDS and all features work, I only paid £50, didn't realise it wasn't genuine till everyone said that's cheap....but it seems to do everything it should
It will be locked to a hacked version of VCDS, so will work fine, unless you try to update the software.
However for cars with MIB2 systems, there are issues coding with older software, so it's risky, you need the latest one, 15.7.4.
Yeah, this is what I'd heard too. Hence stumping up the £210 or whatever.
As above, if you've not bought a genuine cable, you can't do a lot
All I wanted to do was tick the box to disable the exhaust valves so I'm 100% sure the squeak I'm hearing is valves and nothing gearbox related.
Looks like the software won't do that anyway.... Guess I'll ask for a refund.
Shame there is nobody close to you that can do it.
As a temporary alternative, why not unplug them?
I think my closest guy is in Crawley which is about 45 minutes to an hour drive this time of night. I made a thread about unplugging the flaps asking if I was about to unplug the right thing and everyone said do it via VCDS so I got a cheap cable!  :cheesy:
As a quick temporary solution to test if the flaps are what is making the noise, it would work though  :wink:
