markseed007 Posted November 22, 2016 Report Share Posted November 22, 2016 Anyone been able to pair up phone with their R? Tried all i can to no avail... Help.. Any advice.. Thanks in advance Sent from my LG-H850 using Tapatalk Quote Link to comment Share on other sites More sharing options...
goRt Posted November 22, 2016 Report Share Posted November 22, 2016 Anyone been able to pair up phone with their R? Tried all i can to no avail... Help.. Any advice.. Thanks in advance Sent from my LG-H850 using Tapatalk Works for me.Initially get by working. Then ensure the head unit defaults to aa not mirroring, finally plug in. It does force my phone to reboot if phone's been up for more than 4 days. I think there's some memory management issues. Anyway, provide more detail on your problem and we'll try to help. Sony z5 mm.305 Sent from my Nexus 7 using Tapatalk Quote Link to comment Share on other sites More sharing options...
timothyrandell Posted November 22, 2016 Report Share Posted November 22, 2016 Have you followed the steps found in this video? Essentially, you need to enable your phone's media transfer protocol (MTP). Depending on what phone you've got (or, more specifically, the flavour of Android you're running), the steps might be slightly different from those shown in the video. But they should be broadly the same. Sent from my SM-G935F using Tapatalk markseed007 1 Quote Link to comment Share on other sites More sharing options...
hazbot Posted November 22, 2016 Report Share Posted November 22, 2016 Also bear in mind that it can be very sensitive to the cable you are using. First few times I tried to set up AA , it wouldn't work no matter what settings I used. When I switched to a different cable, it worked first time. Try using the USB charging cable that came with your phone if possible. Even if you have another cable that seems to work perfectly fine elsewhere, it might not work well enough for AA. Quote Link to comment Share on other sites More sharing options...
Loconinja Posted November 22, 2016 Report Share Posted November 22, 2016 Works fine for me, but one annoyance is that my hand won't fit in the storage compartment with the USB socket to plug the cable in. I have to fiddle it in with one finger from both hands. Quote Link to comment Share on other sites More sharing options...
goRt Posted November 22, 2016 Report Share Posted November 22, 2016 Have you followed the steps found in this video? Essentially, you need to enable your phone's media transfer protocol (MTP). Depending on what phone you've got (or, more specifically, the flavour of Android you're running), the steps might be slightly different from those shown in the video. But they should be broadly the same. Sent from my SM-G935F using Tapatalk Mtp protocol is a red herring and not required - I never move from the default charging mode. Sent from my sumire using Tapatalk Quote Link to comment Share on other sites More sharing options...
timothyrandell Posted November 22, 2016 Report Share Posted November 22, 2016 If you say so. In my case, it didn't work for me before I enabled it, and did work for me after I enabled it. Clearly our experiences were different. Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Waterloo Posted November 22, 2016 Report Share Posted November 22, 2016 I had a lot of issues getting android auto to work until I used a high-quality usb cable. Several cables that work fine transferring data between a PC and my phone at good data rates failed to work. I assume AA must be using the cable in a non-standard way or to full specification and cheap cables suffer from cross-talk or slightly incorrect wiring. Quote Link to comment Share on other sites More sharing options...
Spinstorm Posted November 22, 2016 Report Share Posted November 22, 2016 I assume that you did download the AA app from the play store. And it did run when you plugged it in. That's the first two steps. If that doesn't work (reboot your phone) and try a different cable. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
caRnage Posted November 23, 2016 Report Share Posted November 23, 2016 Yep. USB cable was my issue too. Any decent quality one should do the job. It's brilliant when you do get it working Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
