AlanR Posted March 1, 2017 Report Share Posted March 1, 2017 Can't get a definitive answer on how to get the climate windscreen working . Had two salesman trying to show me this morning when I collected my new car but they just said google it and can't find anything in the book . Had a look but some say it should work automatically and others say it has to be done manually ,totally confusing ! Quote Link to comment Share on other sites More sharing options...
DriveR Posted March 1, 2017 Report Share Posted March 1, 2017 The interface is naff, but at least the screen works well. To the best of my knowledge, you have to turn it on manually. There is a menu button in the middle of the fan speed dial; push that, then tap the soft button on the touchscreen to toggle it on and off. Quite why they couldn't just put a button in one of the blank spots by the gear lever is beyond me. Quote Link to comment Share on other sites More sharing options...
AlanR Posted March 1, 2017 Author Report Share Posted March 1, 2017 Cheers, that was my question as well this morning ,why didn't they use one of the blanks ! Quote Link to comment Share on other sites More sharing options...
seadragon Posted March 2, 2017 Report Share Posted March 2, 2017 Bloody hell. I just assumed it was automatic. It explains why I thought it was a waste of money and didn't seem to do anything this winter. I will have to look into this further haha !!! Quote Link to comment Share on other sites More sharing options...
DriveR Posted March 2, 2017 Report Share Posted March 2, 2017 Bloody hell. I just assumed it was automatic. It explains why I thought it was a waste of money and didn't seem to do anything this winter. I will have to look into this further haha !!! Next time there's a frost to clear I think you may be pleased with how well it works when you don't reply on the automatic activation feature some VW sales people seem to be miss-selling some people Diesel-gate, Climate-screen-gate, what's next...? seadragon 1 Quote Link to comment Share on other sites More sharing options...
goRt Posted March 2, 2017 Report Share Posted March 2, 2017 Bloody hell. I just assumed it was automatic. It explains why I thought it was a waste of money and didn't seem to do anything this winter. I will have to look into this further haha !!! You can set it to automatic - it's the in the menu where you manually turn it on. Sent from my Nexus 7 using Tapatalk Quote Link to comment Share on other sites More sharing options...
DriveR Posted March 2, 2017 Report Share Posted March 2, 2017 You can set it to automatic - it's the in the menu where you manually turn it on. Sent from my Nexus 7 using Tapatalk I stand corrected then; will have to take a look next time I'm in the car. When it's enabled, do you know what triggers the automatic activation? It would be great if it could be set to come on when the wing mirror de-mist is activated. Quote Link to comment Share on other sites More sharing options...
AlanR Posted March 2, 2017 Author Report Share Posted March 2, 2017 This is the first time I've had it and had to laugh when there was two salesmen flapping trying to show me how it worked and failed ! Had a look and thanks to DriveR I found it . After a bit more investigation through other sources I think there is a sensor on the interior mirror ,just going to check now ,in daylight . Quote Link to comment Share on other sites More sharing options...
DriveR Posted March 2, 2017 Report Share Posted March 2, 2017 So, I decided to find the manual (eek) and figured I'd paste the content here for what it's worth (had to replace the icons with words which I've capitalised in bold)... Windscreen heating First read and observe the introductory information and safety warnings →Introduction The windscreen heating works when the engine is running. Manual windscreen heating Manual air conditioning system: press the MENU button in the Infotainment system. Climatronic: press the COG button on the control panel. Touch the HEATED_WINDSCREEN_ICON (for want of a better description) function button to switch the windscreen heating on or off.The windscreen heating switches itself off depending on the outside temperature or after 8 minutes at the latest. Automatic windscreen heatingThe windscreen heating switches on automatically if there is a risk of condensation building up on the windscreen or windows. Press the MENU button on the control panel.Press the COG function button in the Infotainment system.Switch automatic windscreen heating on or off by touching the Automatic windscreen heating function button. The automatic windscreen heating is also active when the air conditioning system is switched off. Windscreen heating using the defrost function The windscreen heating is switched on if the defrost function is switched on with the MAX button on the control panel and there is a risk of condensation building up on the windscreen or windows. Switch-off conditionsThe windscreen heating will switch off automatically when one of the following conditions applies: If the power consumption is too high. Malfunctions in the air conditioning system. After the time specified has elapsed. flurbs 1 Quote Link to comment Share on other sites More sharing options...
DriveR Posted March 2, 2017 Report Share Posted March 2, 2017 So it seems the MAX button may automatically turn on the climate screen, so I'll try that next time and see what happens Quote Link to comment Share on other sites More sharing options...
seadragon Posted March 2, 2017 Report Share Posted March 2, 2017 I have tried the max thing a lot this winter and I can't say I was blown away by the results. I will take a look using the above instructions and see what I can suss out. I am glad I came across this post, or I wouldn't have been any the wiser Quote Link to comment Share on other sites More sharing options...
iandjm Posted March 2, 2017 Report Share Posted March 2, 2017 I have exactly this issue. I also had the screen on my 2014 Gti and on that car the screen used to switch on and off when needed, and come on when the windscreen demist button was pressed. You could tell this as it showed us on the convenience consumers list when working. on my 2017 R the screen does not show up as working automatically at all on the convenience consumers list. The only time it shows up is of manually activated (ac setup menu, small icon on touch screen) I complained to my dealer who then called VW experts in who confirmed the screen is working automatically, it just does not show up on the convenience consumers list when it is doing so. You can confirm this by tuening the ac off and holdng a mug of boiling water against the screen near to the rear view mirror (the humidity sensor is on the rear view mounting on the screen) You will see the steaming up on the screen starts to clear and does not come back. Make sure you turn off the ac/fan to confirm it is just the screen heating doing this. So in summery the screen is working, but the software on the head unit is faulty in not showing the screen is using any power when it switches on automatically. I much prefer how it was on the Gti Quote Link to comment Share on other sites More sharing options...
iandjm Posted March 2, 2017 Report Share Posted March 2, 2017 So it seems the MAX button may automatically turn on the climate screen, so I'll try that next time and see what happens Mine doesnt sadly despite the manual saying it should and it working on my 2014 Gti Quote Link to comment Share on other sites More sharing options...
PhilC22 Posted March 2, 2017 Report Share Posted March 2, 2017 So it seems the MAX button may automatically turn on the climate screen, so I'll try that next time and see what happens Thanks. Your efforts have probably saved me a lot of hassle! When I spec'd the climate windscreen (the standard fan-based demist function on the Golf is hopeless IMO) the VW salesman said he would find out how it worked before the car arrives (in April/May). He may well do, but I can now at least point him in the right direction. As expressed above, why they couldn't have used one of the blanks as a simple illuminated on/off switch is beyond me. Quote Link to comment Share on other sites More sharing options...
iandjm Posted March 2, 2017 Report Share Posted March 2, 2017 Thanks. Your efforts have probably saved me a lot of hassle! When I spec'd the climate windscreen (the standard fan-based demist function on the Golf is hopeless IMO) the VW salesman said he would find out how it worked before the car arrives (in April/May). He may well do, but I can now at least point him in the right direction. As expressed above, why they couldn't have used one of the blanks as a simple illuminated on/off switch is beyond me. My dealer could not even tell if the car had the climate screen when doing thre PDI ! Quote Link to comment Share on other sites More sharing options...
