VCDS Error Message Help please!
R Soul
Ran a VCDS check yesterday as I've got a dash warning light on indicating a problem with 'cornering lights'. I've checked the lights and they're working perfectly so this is the result of the scan:
Address 55: Headlight Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revision: --------    Serial number: --------------
   Coding: 02A602000B010200
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   VCID: 408F17B6DB1E2141A9-8015
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0002
   Coding: 2E0000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0002
   Coding: 2E0000
1 Fault Found:
13705990 - Databus
          U1123 00 [137] - Received Error Message
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 7
                    Reset counter: 218
                    Mileage: 51286 km
                    Date: 2017.03.04
                    Time: 17:15:21
Any ideas anyone? I've got it booked in for investigation but would prefer to try to sort it out myself if I can!
Also, another fault showed up on the DCC  which has not flagged up any dash warning lights:
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H16 0115
   Serial number: 13021541350109
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC.rod
   VCID: 76E3B16EC95ADFF1C3-8023
2 Faults Found:
198663 - Front Left Ride-Height Sensor
          C1034 11 [009] - Short to Ground
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 218
                    Mileage: 51286 km
                    Date: 2017.03.04
                    Time: 17:15:21
198664 - Front Left Ride-Height Sensor
          C1034 29 [008] - Signal Implausible
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 51329 km
                    Date: 2017.03.07
                    Time: 16:47:56
Again, any help / suggestions would be gratefully received.
Viv
Disconnecting the battery and leaving it for 10 minutes should fix this one. Re-connect and go for a 15 minute drive.
1 Fault Found:
13705990 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Reset counter: 218
                    Mileage: 51286 km
                    Date: 2017.03.04
                    Time: 17:15:21
1 Fault Found:
13705990 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Reset counter: 218
                    Mileage: 51286 km
                    Date: 2017.03.04
                    Time: 17:15:21
Thanks Ash! I'll see if it does the same for the other suspension related faults too  :afro:
It should at least turn the light off if the fault is fixed. If the light goes off then you should be able to clear the codes yourself with VCDS.
If the light remains then I'd still get it booked in at a garage just in case. Do not tell them you've scanned the car yourself as they don't like people doing that!
^^^ Ashley: I hope that your procedure will work, but I'm guessing that the faults will be persistent given that the two major error messages have a Fault Frequency greater than 1. This (generally) means faults are endemic because they have endured for multiple ignition cycles.  In this case, unless R Soul has been making changes with his/her device, I suspect a physical problem
But I'm more than happy to be proven wrong!!
^^^ Ashley: I hope that your procedure will work, but I'm guessing that the faults will be persistent given that the two major error messages have a fault frequency greater than 1. This (generally) means faults are endemic because they have endured for multiple ignition cycles.  In this case, unless R Soul has been making changes with his/her device, I suspect a physical problem
Don,
I think you will be right, the battery test I asked to do is usually to test for low voltage, other reports say if it continues after pulling the battery it could be a faulty steering rack sensor which would align with failing cornering lights.
As for the DCC faults, I have no idea but the 2 could well be connected. Best to start with a simple fix and see what happens before escalating all the way back to being without a car for the day whilst it's in the dealers.
Ash
  • 2 weeks later...
Had the same error for the height sensor twice. The first time the sensor plastic connector/screw had broken so had to replace it (see link below on how the sensor looks). The second time it went away when I disconnected and cleaned the plug.
Edit: I also cropped and attached a photo of how the level sensor looks.
http://forums.vwvortex.com/showthread.php?2882246-Ride-Height-sensor#/topics/2882246?page=1
