Betts-4 Posted April 5, 2017 Report Share Posted April 5, 2017 Few issues Last couple of drives i noticed going from 1st to 2nd the car has clunked into gear almost like a hammer banging against metal, like it was misaligned and got shoved into gear.Also did it on a downshift from 3rd to 2nd and not very smooth.Anyone had a similar issue, was quite soon after starting the car on a hot day though. Also driver side window is not going down automatic or up but passenger side is, anyone had similar issue ? drivers side works but not auto Quote Link to comment Share on other sites More sharing options...
Booth11 Posted April 5, 2017 Report Share Posted April 5, 2017 1 hour ago, Betts-4 said: Few issues Last couple of drives i noticed going from 1st to 2nd the car has clunked into gear almost like a hammer banging against metal, like it was misaligned and got shoved into gear.Also did it on a downshift from 3rd to 2nd and not very smooth.Anyone had a similar issue, was quite soon after starting the car on a hot day though. Also driver side window is not going down automatic or up but passenger side is, anyone had similar issue ? drivers side works but not auto Is it a manual car? Regarding the one touch window opening/closing function, have you tried doing a reset? You can reset individual windows or all of them. This is as per manual: Switch ignition on Make sure all windows are closed Pull the up window button and hold it in position for 2 secs. Release the button, then pull it up again and hold it. Should now have reset and the auto one touch operation restored Think you can also do it this way: Lower the window completely but keep holding the button down for a few secs, then release button Raise the window fully but keep holding the button up for a few secs then release One touch settings should be restored PhilC22 1 Quote Link to comment Share on other sites More sharing options...
Novus Posted April 5, 2017 Report Share Posted April 5, 2017 As Bec says windows should reset no problem following this Quote Link to comment Share on other sites More sharing options...
Betts-4 Posted April 5, 2017 Author Report Share Posted April 5, 2017 2 hours ago, Booth11 said: Is it a manual car? Regarding the one touch window opening/closing function, have you tried doing a reset? You can reset individual windows or all of them. This is as per manual: Switch ignition on Make sure all windows are closed Pull the up window button and hold it in position for 2 secs. Release the button, then pull it up again and hold it. Should now have reset and the auto one touch operation restored Think you can also do it this way: Lower the window completely but keep holding the button down for a few secs, then release button Raise the window fully but keep holding the button up for a few secs then release One touch settings should be restored Thanks i will try AND no its DSG Quote Link to comment Share on other sites More sharing options...
Dominus Posted April 5, 2017 Report Share Posted April 5, 2017 Sometimes when first setting off I get a clunk going from 1st to 2nd, this only happens in paddle mode and never in full auto. It only happens when setting off from work which is always going up a slight hill, dunno if that is significant. It never does this when the engine is warmed up. Quote Link to comment Share on other sites More sharing options...
GrayMK7R Posted April 5, 2017 Report Share Posted April 5, 2017 DSG is always a bit clunky for first change if you pull away from cold. Holds first gear for aaaaaages too. Just the box protecting itself Booth11 1 Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted April 5, 2017 Report Share Posted April 5, 2017 I have suffered the clunk up into and down into 2nd gear with DSG for the first 7000 miles or so, I asked the garage to look at it but it started to behave again a week before going in. They of course found nothing. Recently though (21k miles) I have noticed it has crept back again, I have tried over and over to find a fool proof way to single it out via manual changes, sport to drive, rapid acceleration, deceleration, hot, cold etc etc but it seems to be totally random. My personal take is that there may be some issue with the rev matching and mechatronics of my box around 2nd gear. I will be booking it in fairly soon to get them to take a look, I will be the one taking them on a test drive this time though as it is intermittent enough for them to ignore and avoid a warranty bill if I am not present to push it home. Quote Link to comment Share on other sites More sharing options...
Zayvin Posted April 5, 2017 Report Share Posted April 5, 2017 6 hours ago, Betts-4 said: Few issues Last couple of drives i noticed going from 1st to 2nd the car has clunked into gear almost like a hammer banging against metal, like it was misaligned and got shoved into gear.Also did it on a downshift from 3rd to 2nd and not very smooth.Anyone had a similar issue, was quite soon after starting the car on a hot day though. Also driver side window is not going down automatic or up but passenger side is, anyone had similar issue ? drivers side works but not auto No issues on mine with the DSG noises. I find that on a hot day things are smoother all around due to the oil being hotter. On launching i wheel spin like a muppet though lol. No issues with the window either, soz. Quote Link to comment Share on other sites More sharing options...
Betts-4 Posted April 6, 2017 Author Report Share Posted April 6, 2017 11 hours ago, Dominus said: Sometimes when first setting off I get a clunk going from 1st to 2nd, this only happens in paddle mode and never in full auto. It only happens when setting off from work which is always going up a slight hill, dunno if that is significant. It never does this when the engine is warmed up. Yes this is same as mine, will see if Pirate gets a response if its a DSG issue Quote Link to comment Share on other sites More sharing options...
Betts-4 Posted April 6, 2017 Author Report Share Posted April 6, 2017 11 hours ago, P-P-P-PirateGolf_ARRR! said: I have suffered the clunk up into and down into 2nd gear with DSG for the first 7000 miles or so, I asked the garage to look at it but it started to behave again a week before going in. They of course found nothing. Recently though (21k miles) I have noticed it has crept back again, I have tried over and over to find a fool proof way to single it out via manual changes, sport to drive, rapid acceleration, deceleration, hot, cold etc etc but it seems to be totally random. My personal take is that there may be some issue with the rev matching and mechatronics of my box around 2nd gear. I will be booking it in fairly soon to get them to take a look, I will be the one taking them on a test drive this time though as it is intermittent enough for them to ignore and avoid a warranty bill if I am not present to push it home. Did they check the DSG having read some threads on here i think they can check the system for faults like if you remap it, the fault code shows the eco mapped. The thread was about his DSG having 13 faults in the system, just wondering if each time the DSG is failing and maybe would store a fault Quote Link to comment Share on other sites More sharing options...
