SD frustration
thanksabunch
23 hours ago, TechieAli said:
Try ejecting the sd card safely using the menus then do the factory reset on the media part of the system. The re-insert the memory card. Use the safely remove options in the menus otherwise the media cataloguing gets confused.
Quick update: I followed TechieAli's advice and so far all seems to be working properly.
6 minutes ago, TechieAli said:
Good stuff it worked for me
I tried, ejected the sd card safely but then couldn't find the section to reset the media part.
Went through all the media/music options I could see.
You need to go straight into set up menu on the unit from the button on the lower right on the unit face (rather than the selection available on the media screen). From there you'll find 'factory settings' and in there a sub menu allowing you to select which parts you wish to reset (navigation, radio, media etc). Select 'media'. It's unspectacular, nothing noticeable happens to signify a reset.
Thank you.
