Booth11 Posted July 14, 2017 Report Share Posted July 14, 2017 The last few weeks I have loved the feature, but I must admit to waking up one morning and seeing that all 4 windows where down. I must have sat on the key and it dropped all the windows! On occasion I have come out to the car with mirrors out, but locked. (So indicating it was unlocked, then locked itself as no door was opened) I did not realise one could disable this feature, so given the few days in the year when its needed I think I will! Lucky for me the day it happened was a very dry and warm night. So no harm done. Still taking a last peak out the window every night now to check the mirrors are in and the windows up! It can be a useful feature, and I can see the appeal in the summer months, but too many times on my mk6 which it was enabled on for a time, I came out of work to find the windows dropped, obviously something I was doing with the key! So I disabled it and made sure it was disabled on the R from the off, and don't miss it at all. Given the number of pigeons and seagulls that mill around the car park at work, likely there'd be a present running down the inside of the window come home time. You can disable it in CAR menu - setup - Opening and Closing settings - Window operation- Convenience opening - select OFF. On a keyless car, if you have the convenience windows feature enabled, and you have the windows dropped you can close them by keeping your hand lingering inside the door handle for a few secs. Sent from my iPad using Tapatalk xPETEZx 1 Quote Link to comment Share on other sites More sharing options...
xPETEZx Posted July 15, 2017 Report Share Posted July 15, 2017 23 hours ago, Booth11 said: It can be a useful feature, and I can see the appeal in the summer months, but too many times on my mk6 which it was enabled on for a time, I came out of work to find the windows dropped, obviously something I was doing with the key! So I disabled it and made sure it was disabled on the R from the off, and don't miss it at all. Given the number of pigeons and seagulls that mill around the car park at work, likely there'd be a present running down the inside of the window come home time. You can disable it in CAR menu - setup - Opening and Closing settings - Window operation- Convenience opening - select OFF. On a keyless car, if you have the convenience windows feature enabled, and you have the windows dropped you can close them by keeping your hand lingering inside the door handle for a few secs. Sent from my iPad using Tapatalk Just disabled it Thx. Glad to see I can still raise the windows by holding down the lock button. Funny a colleague just got a car with this feature on, and is very pleased with it! Had it on all 3 of my cars, and although it is handy, Id rather not risk soaked interior. Not sure if its design of the key or what, but I never had any issues with accidental unlocking/window drops previously. Still, the car re-locks so not too worried about that. But the window drop was a scare. Booth11 1 Quote Link to comment Share on other sites More sharing options...
Ignition1 Posted July 18, 2017 Report Share Posted July 18, 2017 Interesting - do you guys all have key-less? Is the button maybe easier to press than the standard key? My standard key unlock button seems pretty stiff to press accidentally - the lock button is easier as it's raised slightly but the unlock is recessed into the fob a bit. Never had an issue with the button being pressed...or if it was, I was too far from my car to do anything Quote Link to comment Share on other sites More sharing options...
Booth11 Posted July 18, 2017 Report Share Posted July 18, 2017 Interesting - do you guys all have key-less? Is the button maybe easier to press than the standard key? My standard key unlock button seems pretty stiff to press accidentally - the lock button is easier as it's raised slightly but the unlock is recessed into the fob a bit. Never had an issue with the button being pressed...or if it was, I was too far from my car to do anything I have keyless but disabled the window drop feature the minute I got the car, so it's not a factor. My mk6 before it was keyless and this is where I had the inadvertant window opening issues - it was no doubt user error but I think the buttons on that key were quite easy to knock. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
xPETEZx Posted July 18, 2017 Report Share Posted July 18, 2017 Mine isnt keyless. But from the pictures, I think physically the keys are the same anyway. It is very odd, as looking at the key, it does not look like the buttons would press easily accidentally. But in my case, they do. Not often. But it has happened about 3-4 times that I have come out to the car in the morning to find the mirrors out but car locked. (IE. it was unlocked, but no door opened so re-locked. ) Then there was the 1 time when all the windows where down. Keep my bunch of keys to a minimum, just 1 other key on there. Same as I did with my previous 2 cars. Yet with the Golf, seems the buttons are pressed more easily in my pockets! Did consider a "case" for the key. But dont want it anymore bulky so left it. Quote Link to comment Share on other sites More sharing options...
jimmy_uk Posted July 19, 2017 Report Share Posted July 19, 2017 19 hours ago, xPETEZx said: Mine isnt keyless. But from the pictures, I think physically the keys are the same anyway. I don't have keyless, but my dad does on his Tiguan. The keys, with the exception of the R silver bit on the bottom, are identical. Quote Link to comment Share on other sites More sharing options...
Ignition1 Posted July 19, 2017 Report Share Posted July 19, 2017 Yes sorry - I've got confused with my old Audi A3 keys where the lock key had a little bump on it! What's more common is me forgetting to lock the car. I'd be cool if the key light flashed to confirm the car is locked. I've sure it can be done simply based on the last successfully detected lock of the car. Problem is if the other key is used to unlock the car by accident Quote Link to comment Share on other sites More sharing options...
