Speedkng668 Posted August 11, 2017 Report Share Posted August 11, 2017 Just wondering, if you had a dsg and the clutch seemed like it was slipping or just needed replacing, what kind of costs do specialists typically charge all in ? Quote Link to comment Share on other sites More sharing options...
Speedkng668 Posted August 11, 2017 Author Report Share Posted August 11, 2017 Just wondering, if you had a dsg and the clutch seemed like it was slipping or just needed replacing, what kind of costs do specialists typically charge all in ? Quote Link to comment Share on other sites More sharing options...
wayne.gill1 Posted August 12, 2017 Report Share Posted August 12, 2017 Just wondering, if you had a dsg and the clutch seemed like it was slipping or just needed replacing, what kind of costs do specialists typically charge all in ?Apr clutch updated are around 1600 mark I'm guessing about 2000 firted Not sure on cost of std clutchSent from my SM-J510FN using Tapatalk Quote Link to comment Share on other sites More sharing options...
ozzyR Posted August 12, 2017 Report Share Posted August 12, 2017 6 minutes ago, wayne.gill1 said: Apr clutch updated are around 1600 mark I'm guessing about 2000 firted Not sure on cost of std clutch Sent from my SM-J510FN using Tapatalk Crikey. Quote Link to comment Share on other sites More sharing options...
Speedkng668 Posted August 12, 2017 Author Report Share Posted August 12, 2017 Thanks. Id imagine fitted for std clutch is around £1500 fitted. What kind of strains can the apr clutch take? Quote Link to comment Share on other sites More sharing options...
Richard_Nottm Posted August 12, 2017 Report Share Posted August 12, 2017 Never needed a dsg clutch on a previous DSG at 100k miles...not sure how long dsg clutches last. Quote Link to comment Share on other sites More sharing options...
invisiblekid Posted August 12, 2017 Report Share Posted August 12, 2017 Is your car tuned? If so does it have a DSG map? I would be stunned if you've killed DSG clutches on standard power/torque unless you have zero mechanical sympathy! Quote Link to comment Share on other sites More sharing options...
Speedkng668 Posted August 12, 2017 Author Report Share Posted August 12, 2017 (edited) Nah completely standard, just wanted to know in advance. My gtr had to have a new gearbox at 15k miles and it was the face lift version, so it should have had the immunity. That's with no launches etc standard power. 530bhp . Edited August 12, 2017 by Speedkng668 Quote Link to comment Share on other sites More sharing options...
invisiblekid Posted August 12, 2017 Report Share Posted August 12, 2017 54 minutes ago, Speedkng668 said: Nah completely standard, just wanted to know in advance. My gtr had to have a new gearbox at 15k miles and it was the face lift version, so it should have had the immunity. That's with no launches etc standard power. 530bhp . DSG cars shouldn't ever burn out a clutch at standard power unless something has gone very wrong or has been seriously abused with launches. Even if heavily tuned you can just map the gearbox to increase clamping pressures which will usually fix any slip. Worst case you upgrade the cluches, but that should be required unless you've gone Stage 3/big turbo. Quote Link to comment Share on other sites More sharing options...
GrayMK7R Posted August 12, 2017 Report Share Posted August 12, 2017 Its clutch packs, not a single clutch like a manual car. The DSG box protects itself from misuse by human error, and being 'wet' it will be slow to wear the clutch packs. Expect 200k miles from DSG clutch packs unless your running silly torque and slipping the clutches in the higher gears (without DSG map). Lots of MK5 GTIs out there with 150k+ on original clutch packs. invisiblekid 1 Quote Link to comment Share on other sites More sharing options...
camelsac2002 Posted August 13, 2017 Report Share Posted August 13, 2017 Just wondering, if you had a dsg and the clutch seemed like it was slipping or just needed replacing, what kind of costs do specialists typically charge all in ?Is yours playing up? What mileage is it on?Sent from my HTC One using Tapatalk Quote Link to comment Share on other sites More sharing options...
