LouCyffer Posted January 21, 2018 Report Share Posted January 21, 2018 I don’t want to deactivate my headlight washers completely, but like some have done, just increase the delay. I use Ross Tech VCDS (17.whatever, so reasonably upto date) but I’ve failed to find the correct channel this evening. Following the thread here, I’m not able to find the channel 3 in the photo below. I do, however find a huge list of channels in the selector drop down for Central Electrics 9. Any pointers please? I’m in a March 15 R. Quote Link to comment Share on other sites More sharing options...
dj219957 Posted January 21, 2018 Report Share Posted January 21, 2018 Headlamp washers Delay Go into [09] Central Electronics Go into Security Access and enter 31347 Go to adaptation channels and set the following: Type "Windshield wiper:" select "SRA Verzoegerungszeit:" set to "2000 ms" marshy and LouCyffer 2 Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted January 21, 2018 Author Report Share Posted January 21, 2018 Thanks my friend. Back to the garage in a few Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted January 21, 2018 Author Report Share Posted January 21, 2018 Coding accepted, 2500ms set. I’ll test it tomorrow dj219957 1 Quote Link to comment Share on other sites More sharing options...
Limey Posted January 21, 2018 Report Share Posted January 21, 2018 How much delay will that give? Dave Quote Link to comment Share on other sites More sharing options...
dj219957 Posted January 21, 2018 Report Share Posted January 21, 2018 2.5 seconds. Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted January 21, 2018 Author Report Share Posted January 21, 2018 I read elsewhere on this forum that 2500ms was the longest delay accepted. I’ll see how (if) it works out & experiment accordingly. Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted January 22, 2018 Author Report Share Posted January 22, 2018 13 hours ago, dj219957 said: Headlamp washers Delay Go into [09] Central Electronics Go into Security Access and enter 31347 Go to adaptation channels and set the following: Type "Windshield wiper:" select "SRA Verzoegerungszeit:" set to "2000 ms" Works a treat! Quote Link to comment Share on other sites More sharing options...
Rich_D Posted January 22, 2018 Report Share Posted January 22, 2018 I did this a few weeks ago, much better as I can now wash my windscreen without triggering the headlamp washers, but if/when I need to clean the headlamps I can still do that. LouCyffer 1 Quote Link to comment Share on other sites More sharing options...
dj219957 Posted January 22, 2018 Report Share Posted January 22, 2018 Forgot to say you do need to tweak the coding so that headlight washers is every time not every three pulls of the stalk. Yes the delay is perfect. Mot freindly but allows you to squirt headlamps when you want. Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted January 23, 2018 Author Report Share Posted January 23, 2018 10 hours ago, dj219957 said: Forgot to say you do need to tweak the coding so that headlight washers is every time not every three pulls of the stalk. Yes the delay is perfect. Mot freindly but allows you to squirt headlamps when you want. I’ve not done that yet. Left it at the standard frequency; I figure that I can get a spray on demand by repeated wash-wipe use anyway so I’ll see how I go. Thanks for the heads up though. I might be asking you which channel to adapt yet.... Quote Link to comment Share on other sites More sharing options...
marshy Posted January 25, 2018 Report Share Posted January 25, 2018 Forgot to say you do need to tweak the coding so that headlight washers is every time not every three pulls of the stalk. Yes the delay is perfect. Mot freindly but allows you to squirt headlamps when you want. I’ve coded mine to 2000ms could you please post the change required to make them work every time. Quote Link to comment Share on other sites More sharing options...
dj219957 Posted January 25, 2018 Report Share Posted January 25, 2018 Go to [09] Central ElectronicsGo into Security Access and enter 31347 Go to adaptation channels and set the following: Type "Windshield wiper:" Select "Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung" Adjust value to preference (no of times you can operate the windscreen washer stalk before the headlight washer activate). so set it as 1 for every time. marshy and Rich_D 2 Quote Link to comment Share on other sites More sharing options...
marshy Posted January 26, 2018 Report Share Posted January 26, 2018 Thank you Quote Link to comment Share on other sites More sharing options...
marshy Posted February 3, 2018 Report Share Posted February 3, 2018 Go to [09] Central ElectronicsGo into Security Access and enter 31347 Go to adaptation channels and set the following: Type "Windshield wiper:" Select "Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung" Adjust value to preference (no of times you can operate the windscreen washer stalk before the headlight washer activate). so set it as 1 for every time. Meant to say is it normal for it to be set to 10 originally? Quote Link to comment Share on other sites More sharing options...
