Cornering lights error
Laths
Error came up saying cornering light error. Both lights no longer come on when u turn the wheel.
Is this a blown bulb which stops either side working or something more sinister ?
i doubt both bulbs blew at the same time. Car is 2 years old but don’t want to take to dealers if I can rectify myself .
The error is usually an indicator that bulbs have blown.  Course it could be something else but I’d start by replacing both bulbs and see if that’s the issue.  Put the car into reverse as the static cornering lights come on when it's in reverse, to double check.
If it is the bulbs, maybe an opportunity to upgrade to better bulbs?
Ideas for upgrading bulbs in here.
Replaced mine due to the same issue a couple of weeks ago.
The warning light showed up on the dash saying there was an issue with the cornering lights. Both cornering lights did not work as a result of this. As Rebecca mentioned, try putting the car in reverse and get someone to see if they turn on. If not, chances are that one of the bulbs has gone but it stops both from working.
I changed the bulbs and it solved the problem. I think I just put some Osram Nightbreakers in as I didn't see the point installing anything too expensive as they aren't on all the time.
Swapped out the diamond visions and put back the original ones and hey presto .
Inspecting you wouldn’t know one had blown apart from a very small break in one of the filaments on one bulb.
What threw me was that both bulbs didn’t work yet only one was faulty .
cheers for comments .
  • 9 months later...
On 05/02/2018 at 12:31, X-Golf R said:
Hi may sound silly but is the car in Eco mode if so it disables the corner lights, I thought mine had stopped working but if you put it in D then move the wheel side to side they work. In Eco mode they don't. Hope this helps
FFS !!!
Didn’t know this , thought mine just didn’t work and have replaced bulbs too!
Will try in other modes later.
How did you find this out, haven’t read it anywhere until two minutes ago ?
  • 6 years later...
1 hour ago, KaiShah said:
Hello, just after a bit of clarity.
I have changed both cornering bulbs which were alot easier than the main headlight bulbs lol
But the warning error has not gone off (yes both cornering lights are working)
Any suggestions ???
Thank you in advance...
Hi,
i had similar issue last year. It ended up being the AFS powermodule "AFS leistungsmodul" placed underneath the headlight that was the problem for me. Part number: 59SKV180.
Best of luck.
