Help with error codes please
KennyGTI
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 52 55 5F A9
VIN: WVWZZZAUZEW305142   Mileage: 56807km-35298miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 B    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 091D00322466050B2004
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM20TFS0205G0906259B 001003
   ROD: EV_ECM20TFS0205G0906259B.rod
   VCID: 2D7FC5DF7C1A0E2240-8078
6 Faults Found:
17789 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [101] - -
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 56783 km
                    Date: 2019.01.09
                    Time: 19:11:24
                    Engine speed: 1025.25 /min
                    Normed load value: 2.7 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 65 °C
                    Intake air temperature: 49 °C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 11.601 V
                    Unlearning counter according OBD: 40
                    Engine: operating status: IS
                    Engine temp. management actuator: raw value: 1586
                    Engine temperature management actuator: stop open: 135
                    Engine temperature management actuator: after-run stop: 3956
                    RVC_SP: 164.50 °
                    RVC_AV: 96.84 °
                    RVCPWM: -100.000 %
15462 - Control Circuit for Coolant Bypass Valve
          P2681 00 [040] - Open Cricuit
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 40
                    Mileage: 56490 km
                    Date: 2018.12.30
                    Time: 17:27:21
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Coolant temperature: 17 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 11.699 V
                    Engine: operating status: ES
                    Engine temp. management actuator: raw value: 1474
                    RVC_SP: 88.75 °
                    RVC_AV: 89.23 °
                    RVCPWM: 0.000 %
15470 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [237] - -
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 56783 km
                    Date: 2019.01.09
                    Time: 19:11:26
                    Engine speed: 877.75 /min
                    Normed load value: 4.7 %
                    Coolant temperature: 64 °C
                    RVC_SP: 76.78 °
                    RVC_AV: 96.84 °
                    RVCPWM: 100.000 %
16986 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [101] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 56788 km
                    Date: 2019.01.09
                    Time: 20:34:02
                    Engine speed: 837.00 /min
                    Intake air temperature: 50 °C
                    Voltage terminal 30: 11.718 V
                    Engine temp. management actuator: raw value: 1967
                    Engine temperature management actuator: stop open: 145
                    Engine temperature management actuator: after-run stop: 3948
                    RVC_SP: 102.50 °
                    RVC_AV: 122.16 °
                    RVCPWM: 100.000 %
16464 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [040] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 56791 km
                    Date: 2019.01.09
                    Time: 20:42:03
                    Coolant temperature: 98 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 12.031 V
                    Engine temperature management actuator: stop open: 1967
                    RVC_SP: 5.75 °
                    RVC_AV: 131.88 °
                    RVCPWM: 100.000 %
16465 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [039] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 56807 km
                    Date: 2019.01.10
                    Time: 18:00:23
                    Coolant temperature: 49 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 12.050 V
                    Engine temp. management actuator: raw value: 151
                    Engine temperature management actuator: stop open: 156
                    Engine temperature management actuator: after-run stop: 151
                    RVC_SP: 0.00 °
                    RVC_AV: 0.00 °
                    RVCPWM: -100.000 %
Readiness: 0000 0000
Anyone got any information on the codes above??
I'm no expert but if it is coolant related there is a well known common fault with the thermostat housing leaking coolant, also the water ump is prone to failure. Do you get a low coolant warning on the dash, if you do and you open the coolant tank and it back fills that's a telltale sign.
Again, no expert myself but this looks suspiciously like the coolant bag split issue that is a common fault with these cars.
Check the bag has not split inside the coolant reservoir. Standing in front of your car, you can find the bag to the right hand side of the tank.
A tell tale sign is apparently the heater matrix failing and then the heaters in the car being at different temperatures ie side hot and middle cold
Thanks Dave, didn't know that.
Wish we had a sticky thread for common faults and tell tale signs, would be very useful.
