Lumpy idle
Stefan88
Afternoon all.
Having a little issue with the golf ATM.
When I'm at idle the revs are dropping almost like the car wants to stall.
It doesn't do it all the time but it's becoming more often than not.
Had the water pump changed due to the common leak hoping it was that but afraid not, any suggestions.
Stef.
So I've just got the car back.
It's completely random.
When stationary it might idle perfect for 30s Upto 5 min the 4/5 chugs id decsribe them as then normal idle again. Only when the idle returns to normal again the rev needle just flickers up 100rpm then back to normal. During the chugs it doesn't move but you can feel it through the car.
Hi Stef,
Is it worth checking the various fuel pressures using the live data / gauges on OBDELEVEN and see if there’s any correlation between the rough idle and the fuel system? Could be a faulty or failing fuel pressure switch?
It may also be worth monitoring misfire as well.
Clear those errors, if they come back then it's indicative of timing chain stretch or chain tensioner issues.
How many miles on the car? - also are you UK/EU based or US?
UK based buddy 65k never missed a service etc
Ok, well UK model rules out any intake coking build up.
With those errors you have, it does indicate the timing is somewhat out. Could be a sensor issue but less likely as the fault is a correlation rather than an intermittent electrical fault.
If the timing is out (due to chain stretch or tensioner issues) then symptoms will be a lumpy idle and a general reduction in power.
Clear the errors, see if they come back after a good drive.
I've only shown the basic photo of the error codes. When you open them up they both say intermittent fault of they come back tomorrow IL snapshot the full error code. No lack of power at all car drives smoothly as she should. It's literally lumpy on idle for a few seconds randomly.
It's all started since the car was serviced. It did have new sparks but I'd find it difficult to believe if they were causing an intermittent fault rather than a constant one.
I wonder if they didn't install a coil pack properly on one plug, or some other connection is a bit dodgy ?
I did think this but I did the sparks myself like alot of the straight forward things. I'm going to go over it all and check connections etc when I get chance.
We are unfortunately in a pretty shitty position ATM we have lived in the hospital for 3 and half weeks now our 2 year old girl is poorly so any spare time is non existent just need to try have the car running as smooth as poss with the missus travelling home for shower and clothes etc. Had the car for 4 years and never missed a beat typical when you need it the most.
Have you tried a throttle body re-adaptation (GX3) although this would normally have been done if  throttle body is removed when cooling module (N493) & water pump are replaced? This is removed instead of the whole inlet manifold if you follow manufacturers instructions and needs to be clean and be correctly adapted to the engine control module or it will coke up. This can be done using VCDS and official and other tools of course.
Other rough idles could be linked to leaking oil separator (PCV valve). Had a dodgy oil cap on a S3 8v on wife's car and idle was lumpy as hell. Tried throttle adaptation but could hear a slight hissing sound. Replaced cap and all was good again.
Thanks IL look at them appreciate it.
How can I re calibrate the throttle body with obd eleven?
