Peterb3n Posted April 29, 2019 Report Share Posted April 29, 2019 Hello everyone, New to the forum and to the Golf R. Picked up my new 19 7.5R about 10 days ago and I like to have a tweak of all my cars and the Golf is no different. From reading through the forums, I've decided upon a JB4 and a pedal box, but I'm not sure on which pedal box. Any recommendations on which one to go for? Also, is there anything else that I could/should be considering for stage 1 (don't want to go too crazy just yet). Thanks in advance. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 29, 2019 Report Share Posted April 29, 2019 DTUK pedal box works perfectly, cant see a reason to get a different one, good choice with the JB4, I'm no expert on what supportive mods to so with one, everyone seems to suggest different ones to be honest, take your choice.I would invest at least in some decent brake pads as always best to make it stop before you make it go faster. Cam also recommend some good paddle shifters, replacement ones not stick on. Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Peterb3n Posted April 29, 2019 Author Report Share Posted April 29, 2019 Cheers Dave. I'm already running an r600 which I transferred from my last car (octavia vrs) so that's one other thing I forgot to mention. Is the JB4 a difficult fit? I ran a DTUK box on the old motor which was fine, but the jb4 seems to get the vote on the golf with a few added fitting steps over the dtuk. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 29, 2019 Report Share Posted April 29, 2019 Cheers Dave. I'm already running an r600 which I transferred from my last car (octavia vrs) so that's one other thing I forgot to mention. Is the JB4 a difficult fit? I ran a DTUK box on the old motor which was fine, but the jb4 seems to get the vote on the golf with a few added fitting steps over the dtuk. Not particularly difficult, you need to take the under tray off to go one connection so ramps are handy, most tricky bit is feeding the OBD connector through the firewall behind the battery, there are some good videos and how to's on utube etc. I've fitted mine on to 2 R's and hopefully onto a 3rd this weekend if it gets sold Sent from my SM-G950F using Tapatalk Peterb3n 1 Quote Link to comment Share on other sites More sharing options...
R-Estate Posted April 30, 2019 Report Share Posted April 30, 2019 DTUK pedal box seems to be the one to go for. Reckon discount code RF80 still works. If you want to be able to tweak the settings via an app then they’ve now got this on the Pedal Box+.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ellixtt Posted April 30, 2019 Report Share Posted April 30, 2019 Eibach Pro Springs! Much better improvement over stock and not too low to scrape Quote Link to comment Share on other sites More sharing options...
Peterb3n Posted April 30, 2019 Author Report Share Posted April 30, 2019 4 hours ago, R-Estate said: DTUK pedal box seems to be the one to go for. Reckon discount code RF80 still works. If you want to be able to tweak the settings via an app then they’ve now got this on the Pedal Box+. Sent from my iPhone using Tapatalk Sadly it seems that the forum discount code is no longer valid 😔 Quote Link to comment Share on other sites More sharing options...
Peterb3n Posted April 30, 2019 Author Report Share Posted April 30, 2019 3 hours ago, ellixtt said: Eibach Pro Springs! Much better improvement over stock and not too low to scrape I hadn't really considered tweaking the ride just yet. I had Eibachs on a mk2 Fabia VRS and found they caused some issues with speed bumps, but I did have mudflaps on it which were the source of the scraping. Any similar issues with lowering the Golf? Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 30, 2019 Report Share Posted April 30, 2019 No plans to lower mine, too many speed bumps around me unfortunately even standard with my front lip I catch it very occasionally...Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
R-Estate Posted April 30, 2019 Report Share Posted April 30, 2019 Sadly it seems that the forum discount code is no longer valid Boo. Code ‘SPRING’ will get you 5% off.Sent from my iPhone using Tapatalk SpursMadDave 1 Quote Link to comment Share on other sites More sharing options...
mp2811 Posted April 30, 2019 Report Share Posted April 30, 2019 I think JB4 and pedal box will be great improvement. Ive found rear sway bar good handling mod without any negatives on daily driving when you’re looking at handling upgrade. Another good cheap mod is the dog bone insert to tighten engine movement once tuned. A good detail and ceramic coat a good starting point for car to look best and easy maintenance. Quote Link to comment Share on other sites More sharing options...
Peterb3n Posted April 30, 2019 Author Report Share Posted April 30, 2019 32 minutes ago, mp2811 said: I think JB4 and pedal box will be great improvement. Ive found rear sway bar good handling mod without any negatives on daily driving when you’re looking at handling upgrade. Another good cheap mod is the dog bone insert to tighten engine movement once tuned. A good detail and ceramic coat a good starting point for car to look best and easy maintenance. Ceramic coating scares the bejesus out of me. I've thought about it but no idea where to look for a detailer to do it properly, not something I'd want to try myself as I've never been very good at detailing. Dog bone insert a difficult install? Presumably would need a lift so not a DIY task? Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 30, 2019 Report Share Posted April 30, 2019 Ceramic coating scares the bejesus out of me. I've thought about it but no idea where to look for a detailer to do it properly, not something I'd want to try myself as I've never been very good at detailing. Dog bone insert a difficult install? Presumably would need a lift so not a DIY task? I've thought about a dogbone mount but I'm not sure the benefits for me outweigh the extra vibration at lower speeds, each to their own as they say...Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Peterb3n Posted April 30, 2019 Author Report Share Posted April 30, 2019 Just now, SpursMadDave said: I've thought about a dogbone mount but I'm not sure the benefits for me outweigh the extra vibration at lower speeds, each to their own as they say... Sent from my SM-G950F using Tapatalk Good point. I do a lot of town driving so generally most of my work is at low speeds. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 30, 2019 Report Share Posted April 30, 2019 Good point. I do a lot of town driving so generally most of my work is at low speeds. Same here mine is also my daily so that's why I'm not lowering etc Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
